is the d201gly2 out yet?? no one has a listing or can tell me if it has even been released yet buy.com say not in stock...sata and 1.2G fanless or pata and 1.33 with fan??
Actually I got it at buy.com with Google checkout...
I meant I bought if for a good deal there only 1-2 weeks ago. If I had known about ver 2.0, I would have just spent the extra few $$ and bought that instead.
Back on the heatsink note... this looks like an option...
http://shop.intel.com/shop/product.a...d=116&pindex=1
hmm... nmaybe not...
Logic Supply says that this will work, but it doesn't look like it to me...
http://www.logicsupply.com/products/epiahsfan
peak draw was provided to 12v pico (which converts to seperate 12 and 5 rails).
to the overall power consumption
battery draw about 42-43 watts
12v pico: 35-36 watts
5v usb hub, dvd, antennas etc.: 4 watts
this gives around 40 watts in total for the system compared to 43 watts from battery taken - or an efficiency of about 93-95%!
see, the efficiency of psu and dc-dc regulators is key. who cares about cpu wattage if you loose all the savings with a badly psu again. and it also keeps things cool(er)
I want to get this board but I have a few questions I would like to clear up. Hopefully someone can answer these from experience.
1. Can StreetDeck be run with the Intel D201GLY board? (or is there someway to trick it into thinking that DirectX 9 is installed)
2. Will the integrated graphics support 640x480 resolution?
For the power consumption of the board itself:
Check the Intel boad notes from their website (section 2.5). The power consuption can range anywhere from 45W to 175W. Obviously those numbers are specific to what is plugged into your board and how hard the processor is working. Just remember Power = V*I!! Each USB port can draw up to 2.5W if whatever is plugged in is pulling the full 500mA.
Any chance the store here will get version 2 of this board?
TruckinMP3
Read the FAQ!
Looks like version 2 with the celeron 220 processor is actually slower than the 215.
this is all i could find:
220: http://en.wikipedia.org/wiki/List_of...icroprocessors
and then for 215: http://processorfinder.intel.com/Det...px?sSpec=SLA4L
from those two pages 220 -> 1.2 ghz while 215 -> 1.33ghz
i guess thats why they can go fanless?
im not sure what would be best for carpc performance; that extra .13 ghz or sata?
Quoting www.xtreview.com:
"On 21 October Intel company will present new processor for use in mini-ITX motherboards . It is known to us by the name Celeron 220 (1.2 GHz). This processor has the lower frequency and equal cache volume in the second level (512 KB) , this processor has lower TDP in comparison with preceding celeron 215 (1.33 GHz).
We succeeded in learning, that this nonconformity is caused by the passage of processor to Conroe- L core. Let us recall that Celeron 215 (1.33 GHz) was based on mobile core yonah, and it do not support 64-bit expansions. The TDP level of this processor was equal to 27 W. Passage to the desktop core Conroe- L will allow not only the 64- bit expansions support , but also will lower level TDP to 19 W. It is understandable that increase in speed will occur, in spite of reduction in the frequency from 1.33 GHz to 1.2 GHz.
The processor celeron 220 (1.2 GHz) will be more expensive than its predecessor by four dollars, since its wholesale price is equal to $58. If we considers that this processor will be used in intel D201GLY2 motherboard on base of chipset SiS 662, whose retail price will not exceed $90-100 (cost of processor is included on), addition in price can distress potential buyers. However, increase in speed and 64-bit applications compensate in certain degree the price increase. "
http://xtreview.com/addcomment-id-35...leron-220.html
64-bit? I suppose that industrial applications and such would make use of 64-bit processing, but CarPCs, HTPC and other home/consumer applications won't have much use for 64-bit processing at this time. As a matter of fact, wouldn't most applications where you would want/could make use of 64-bit processing require much more processing power both CPU-wise and video-wise than this board...?
Either way... the addition of SATA is nice.
Its just the same 64-bit extensions that every other new chip has had for the past 3 years. In other words, you could, if you wanted to, install Vista x64, or XP x64 and expect half the hardware to work faster or slower, and half the hardware not to work at all.
Or.. you could still just install the 32 bit versions and it'll function just like the non-64 bit extended version. Just slightly faster/cooler as explained in makman's post.
Is it that it's fun? Or that it lets you forget yourself?
