Page 19 of 30 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 298
Thread: Intel MINI-ITX board - D201GLYL & D201GLY
  1. #181
    Nov 2005
    WARNING: DON'T UPGRADE TO LATEST BIOS. it deactivates all pci bus 0 devices (lan, sound, usb)
    after hours reading the internet i was finally able to create a bootable usb flash disk and downgrade my bios to a recent version (took one from august to be safe). now everything is up and running again. BLAME ON YOU INTEL
  2. #182
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    What is the height of BLKD201GLYL??? i am wondering if it would fit vooompc-2 case?
  3. #183
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by kickercivic1 View Post
    I think there is now a thread about replacing it with the $15 1U heatsink which will fit. That thread has pictures comparing the original and the afterwards and the 1U is much smaller. So I am thinking originally it wont fit.
    1.9in x 2.9in -- 47mm x 73mm
  4. #184
    May 2003
    Florida
    I thought BoxD201GlyL is one with fan on it?
  5. #185
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by upspace View Post
    Uhm.... my sound and USB are fine.... I have not hooked up an network cable....
    Are you sure it was not a different cause?
    TruckinMP3
    Read the FAQ!
  6. #186
    Feb 2008
    Regarding slow boot / post times another person pointed out that disabling legacy USB in the bios improved boot times. I can confirm this. Post times ranged anywhere from 30 seconds to 2 minutes on my system. Once i turned off legacy USB support my post times were cut down to a few seconds. This board is working very nicely now.
  7. #187
    May 2007
    Wichita, KS
    Quote Originally Posted by 2k1Toaster View Post
    which thread is that? i replaced mine with a northbridge heatsink off an old motherboard
  8. #188
    May 2007
    Wichita, KS
    Quote Originally Posted by hotjava View Post
    yup this board is really fast IF legacy usb is disabled. but that could cause problems if you use a usb keyboard to get into your bios if things go haywire... or maybe not? what exactly does legacy usb do? i thought it was for keyboards etc...?
  9. #189
    Low Bitrate maniaxzero's Avatar
    Apr 2005
    Queens, NYC
    Quote Originally Posted by Lithoss View Post
    I would like to know the answer to this question too. I would like to disable it but what problems can it cause with it disabled?
  10. #190
    Apr 2005
    Queens, NYC
    i updated to the latest bios with the windows utility and no problems here.
  1. Mac mini (Intel) and CNX-P2140
    By atl in forum MacCar
    Last Post: 09-06-2010, 10:18 PM
  2. where can i get a mini ITX for cheap
    By D_roc in forum Newbie
    Last Post: 09-24-2007, 06:55 PM
  3. Intel Itx board into C134
    By Craggy in forum General Hardware Discussion
    Last Post: 10-09-2006, 07:06 PM
  4. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 09:46 PM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 04:20 PM
