Page 3 of 30 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 298
Thread: Intel MINI-ITX board - D201GLYL & D201GLY
  1. #21
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    We have added the D201gly to the store.
    http://store.mp3car.com/Intel_D201GL..._p/mtb-053.htm
    Hopefully we can have a performance review online within the next couple of days.
  2. #22
    Nov 2005
    Penang
    I have tested the board, mp3, mp4, rmvb wise no problem for single program.. if multiple.. it's will hang and loaded with 100% CPU utilisation... and u know wat, the bios say it support for 800x480, i m going to try that in this weekend with my lilliput 619GL, hopefully can...
  3. #23
    Newbie CorMan's Avatar
    Jun 2004
    Macon, GA
    Has anyone used this board yet?
  4. #24
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    We should have some results from our testing online Tomorrow.
  5. #25
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    So far so good, check out this other thread and let us know what you think:
    http://www.mp3car.com/vbulletin/suggestions-comments/106169-399-intel-car-computer.html
  6. #26
    Apr 2007
    Hi all, first poster from a noob who's been lurking around looking at stuff on this site for a year or so now. Don't actually have any Car PC parts yet although I build regular PCs pretty often.
    This board looks really interesting to me, except for a couple questions... Since it doesn't have S3, what's the best way to set this up so it doesn't drain your car battery? Just have it power up and down the same way a radio would, so it's only running when the car is running, and when the key is in position to run the electical stuff? (sorry for the non-technical description).
    How long does this thing take to boot up?
    I think this could be a nice lowbudget solution, if power-up time is acceptable, or if there's another way to work around the lack of S3 state.
    Thanks for any replies!
  7. #27
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Hi! I am interested in this mother board. I already have the M2-ATX and other parts, and currently using a regular PIII from an old computer. I think that is a good option to reduce the size of my case (which I am about to fabricate), that will reside on the trunk.
    Couple questions:
    1) Does it support hybernation?
    2) Does it support 800x480 resolution?
    3) Do you think it will be enough to run RoadRunner, Destinator and Videos? (basic)
    If it does it all, I will post my order asap, and also some friends from my region.
    Thanks!!
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  8. #28
    Nov 2005
    you need a startup/shutdown controller (such as the carnetix) which is wired with the power button of your motherboard / case.
    i placed an additional button left to the steering weel on a permanent 12+ v wire. when pressing it, it pulses the carnetix to start / shutdown which then forward this signal to the pc, amplifier etc. pc power mode is set to hibernate on power down - 5 seconds to resume from hibernation, no battery draining at all (standby a couple of days would drain your battery as well!!!)
    this seems the best approach to me as you can manually control when to start / stop your electronics. don't want to turn off (hibernate) pc every time at the gas station, washing car, going to atm etc.
    BTW the carnetix monitors the battery voltage. if it is becoming critical (let's say you forget to push the button to stop your pc) it is going into a forced state, sending the pulse to shutdown devices and physically disconnecting from the battery to consumers.
    hope this helps.
    P.s. just got my 201gly today. will install rr, vlan etc. and come back with performance figures
  9. #29
    Nov 2006
    Sao Paulo, Brazil
    The M2-ATX has the startup/shutdown controller feature.
    At this time I just need to confirm if hybernation and 800x480 is supported in this intel mother-board.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  10. #30
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by vladcarpc View Post
    hibernation and 800x480 are supported.
  1. Mac mini (Intel) and CNX-P2140
    By atl in forum MacCar
    Last Post: 09-06-2010, 10:18 PM
  2. where can i get a mini ITX for cheap
    By D_roc in forum Newbie
    Last Post: 09-24-2007, 06:55 PM
  3. Intel Itx board into C134
    By Craggy in forum General Hardware Discussion
    Last Post: 10-09-2006, 07:06 PM
  4. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 09:46 PM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 04:20 PM
