Page 4 of 30 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 298
Thread: Intel MINI-ITX board - D201GLYL & D201GLY
  1. #31
    Nov 2005
    successfully set up my intel d201gly yesterday and did some testing...
    this board is FANTASTIC always considering the price of about 69$!!! it uses average 15-20 watts, plays divx with 10% cpu usage, h264 pal/ntsc with 50% (who needs full hd on a 7/8 inch screen anyhow), is always responsiveness, hibernates (takes a while from bios to de-hibernation - probably a a bios setting i have to change).
    the only problem i have seen are some 3d-effects not working (what is the onboard gpu - 7 directx?). also the digitalfx does not work (flash or again 3d/directx problem)
    @fiberoptic. how did you get 800x480 to work, only saw 800x600 listed. driver update or some (hidden) advanced settings?
    happy now.
  2. #32
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by upspace View Post
    You mean that RoadRunner with DigitalFX 2.0 skin doesn't run? D@mn this is my skin of choice. I hope its just a DirectX or Flash installation/upgrade issue, software, not the mobo.
    I'm interested in that subject too.
    happy now.
    If RR and DigitalFX 2.0 run, I'll be happy too. If 800x480 works, I think I'll cry. hahaha
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  3. #33
    Good luck! The motherboard uses SIS Mirage graphics. FYI, my mobile phone has a better graphics core!!
  4. #34
    Nov 2006
    Sao Paulo, Brazil
    Accordingly to the following site it does not support 800x480:
    http://www.cartft.de/de/catalog/syst...dex_html?qs=40
    \/ |_ /\ [)
    1995 Civic Sedan EX
  5. #35
    Jan 2007
    D201GLY and m2-atx
    How do you use the m2-atx powersupply with the D201GLY motherboard if it doesn't have the little 4 pin 12v power for the CPU?
    I also see that there is a m2-atx-HV that gives up to 8A on the 12v rail but it also lacks the 4 pin 12v connector for the cpu.
    Can I just buy the m2-atx-HV and not plug in the 12v connector?
  6. #36
    Oct 2005
    Raleigh, NC
    Confirmed 800X480 and initial observations
    Hi all,
    I just picked up this board, and confirmed that it does support 800X480 with the SIS drivers/utility that come on the CD - no need for powerstrip.
    I just started testing, but my initial observations are as follows:
    - 240 pin DDR2 RAM. In my entire junk pile, not a single module would fit this board. Off to Tiger Direct I went. $24 for a 512MB stick. Check the technical product specifications PDF from the below URL for important RAM requirements.
    - Updated to the latest version of BIOS,
    - Navigating the BIOS is sluggish as mentioned by another poster, but not a big deal.
    - It supports USB booting. I was able to boot XP from a USB thumbdrive, however VERY slow. Probably booting in USB 1.1 mode.
    - Intel Rapid BIOS is a bit of a stretch. I takes nearly 5 seconds from power on to see the Intel splash screen, then a few more seconds to initialize before booting. There are few options you can manually set, so all devices are auto detecting.
    - Boot speed is decent with a Samsung 7200 RPM HDD
    - With 512MB RAM, resuming from hibernate is VERY fast, once you get past the POST.
    - I tested with RR and IG3, and the CPU utilization was low. Navigating the OS and RR was very smooth.
    - I don't play DVDs or games, so can't comment on performance in those areas.
    - No obvious way of changing the OEM splash screen to a custom one (yet).
    Overall, I'm happy with this board. Compared to my EPIA C3 800MHz, this board has a lot more horsepower, the CPU runs fairly cool and the fan is quiet. If you can get past the slowish POST, and not a power user, this little guy is a good solution at a good price point.
    http://support.intel.com/products/mo...1GLY/index.htm
  7. #37
    Nov 2006
    Sao Paulo, Brazil
    Question Hibernation?
    Quote Originally Posted by rrgcsfb View Post
    Hi all,
    I just picked up this board, and confirmed that it does support 800X480 with (...)
    Hi rrgcsfb,
    Did you test hibernation? I had a problem with another board that using 800x480 resolution the driver won't let the PC hibernate... Plese, can you test it?
    I agree with you that this board has a good cost benefit. Thank you for sharing your test results.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  8. #38
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i just got one too.. only played with it briefly but i didnt see an option for 800x480. Notta big deal to me though because i use an 8 inch 4:3 screen. Its a quick little board for the money. My only gripe is that the onboard audio is for some reason limited to just 2 channel output when its clearly built with 6 channel components.
    Live mp3Car Facebook Chat
  9. #39
    Oct 2005
    Raleigh, NC
    800X480 and hibernate - works fine
    vladcarpc - I tested, and hibernate works fine @ 800X480. Did you try the latest video drivers from the Intel site?
  10. #40
    Oct 2005
    Raleigh, NC
    Custom splash screen
    For those interested in using a custom BIOS splash screen, this utility from Intel will allow you to insert your own JPG or BMP in the .BIO file
    http://www.intel.com/design/motherbd...k/download.htm
  1. Mac mini (Intel) and CNX-P2140
    By atl in forum MacCar
    Last Post: 09-06-2010, 10:18 PM
  2. where can i get a mini ITX for cheap
    By D_roc in forum Newbie
    Last Post: 09-24-2007, 06:55 PM
  3. Intel Itx board into C134
    By Craggy in forum General Hardware Discussion
    Last Post: 10-09-2006, 07:06 PM
  4. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 09:46 PM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 04:20 PM
