Page 7 of 30 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 298
Thread: Intel MINI-ITX board - D201GLYL & D201GLY
  1. #61
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    fyi- This board does NOT work with High-Density Ram modules.. which means i wasted 24 bucks on the ram from ebay i purchased.. but circuit city has a compatible 1GB module for 44 bucks! i dont feel so bad now !
    Live mp3Car Facebook Chat
  2. #62
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    This motherboard came with an IDE cable like this:
    http://www.pcguide.com/ref/hdd/if/id...Cable80-c.html
    (it has blue, gray black and connectors)
    Can I use the old IDE cable I have???
    The 2.5 HDD Adapter won't fit in this new IDE Cable (the connector of the new cable has 1 pin less, in the middle, that is blocking)
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  3. #63
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    just look around you can find a cable that doesn't have that pin blocked or break the pin off the adapter, i've done that also.
    I just got back from the store and bought a 18" round to replace the flat one I had so I know they are available.
  4. #64
    Constant Bitrate Tensai's Avatar
    Jun 2006
    Texas
    If you're not up to breaking the pin off. Simply bending it out of the way will work equally well. I've done that before. But the nice round cables don't cost much.
    Here is a round one (12") from TigerDirect for $4 + $7.50 shipping
    http://www.tigerdirect.com/applicati...?EdpNo=1910188
  5. #65
    Nov 2006
    Sao Paulo, Brazil
    OK, I will see if I have one or buy that cable.
    But is there a problem using the old IDE cable?
    I am asking because I just did it and the Motherboard is not booting anymore. It was fine before.
    Green light in the motherboard is lit, CPU fan is on, but monitor doesn't show anything... It doesn't have a speaker so no beeps.
    I powered all off, removed the IDE cable, start but no luck...
    Anything I should try now? I just removed all the cables, and took the bios battery out...
    Please help...
    \/ |_ /\ [)
    1995 Civic Sedan EX
  6. #66
    Nov 2006
    Sao Paulo, Brazil
    Hello,
    Left all unplugged during the night. This morning I connected power, kbd, memory and monitor.
    Turn the board on, green light is on, Keyboard num caps scroll locks blink once, CPU fan is on, but no video....
    Do you know if this board have a Speaker connection? Maybe its beeping something.
    Help
    \/ |_ /\ [)
    1995 Civic Sedan EX
  7. #67
    Woodbridge, VA
    Blog Entries
    32
    check the position of your bios reset jumper. if its on pins 1-2 power down, move it to 2-3 and reboot. You'll get into the maintenence section of the bios. Check the error log for any available info.. then save the default bios setting. Power down, and move the pin back to 1-2. It should work then. This board is a little pushy when it comes to having every scenario correct to make it boot. I went thru a week of tryin to figure out various things that seemed to be wrong with it.
  8. #68
    Nov 2006
    Sao Paulo, Brazil
    Hi, i tried with jumper in 2-3 position, turn on but still no video. Light on, CPU Fan on, ... I also tried without the jumper.
    Extra testing:
    I plugged my USB GPS and it turned on (so there are power in the usb port), I plugged a network cable and its lights blinked, so I dont understand what is going on...
    I was thinking if that is a problem with my LCD monitor (boot resolution, maybe), so I changed to a 17" CRT monitor, but no luck.
    I connected a led in the Power On led. It is lit when the board is on. I removed the DIMM, turn on and the power led is not continuously on, it blinks, probably the error code.
    Sad.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  9. #69
    Jun 2006
    Texas
    That LED blinking should definitely be the error code. Look it up in the documentation. I don't remember if that document actually came with the board or not so you might have to download it from this page at intel.
    I doubt that it was the IDE cable that caused it. Older cables should work just fine (although they might not get you the full ATA133 throughput). If there was a problem with the IDE then you should still see the logo/post screens and might even get a "Non System Disk" error.
    I was getting similar symptoms from my VIA800 before I bought this board. All lights on, fans spinning, nothing else. I tried resetting the BIOS as per the instructions in the manual with no results at all. Eventually I took the BIOS battery out, and left the board unplugged for about 4-5 days. I tried it again the next week, just for kicks, didn't expect it to do anything. And it booted up as if nothing was ever wrong.
    That may not be very helpful to you, but take it for what its worth.
  10. #70
    Nov 2006
    Sao Paulo, Brazil
    It is back alive!!! I changed the DIMM and it worked!!!
    Maybe I screwed the previous DIMM with some static or whatever.
    I'm happy again.
    Well, let's continue the tests.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  1. Mac mini (Intel) and CNX-P2140
    By atl in forum MacCar
    Last Post: 09-06-2010, 10:18 PM
  2. where can i get a mini ITX for cheap
    By D_roc in forum Newbie
    Last Post: 09-24-2007, 06:55 PM
  3. Intel Itx board into C134
    By Craggy in forum General Hardware Discussion
    Last Post: 10-09-2006, 07:06 PM
  4. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 09:46 PM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 04:20 PM
