Results 1 to 6 of 6
Thread: Help me figure out what has my COM1 tied up?
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    I have serial car diagnostic software on my carPC. But about a month ago when I try to connect with it, it tells me the port is in use, and my diag software wont connect.
    I havent installed anything else new on my PC.... Just all the sudden my PC has COM1 tied up even after boot.
    I have the /NOSERIALMOUSE in the boot.ini so its not thinking is a serial mouse. I cant figure it out... Is there a DOS command of some sort that will tell me what has it tied up???
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Dec 2006
    Jacksonville, FL
    I found this googling "what is using a com port
    1) Start|Run|type msinfo32|OK. This opens the System Information window. In the left panel click Component and then Port. You may learn what is connected to COM1. Belarc Advisor or Everest may also tell you
    http://www.belarc.com/free_download.html
    http://www.majorgeeks.com/download.php?det=4181
    2) This article, while quite old. has much info which is still valid
    http://www.smartcomputing.com/editor...0205.asp&guid=
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    What FE are you using?
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Jun 2007
    Sydney, OZ
    have u enabled the port in ur Bios???
    Feb 2004
    Florida
    Thanks for the info everyone.
    I also found a MS tool called ComDisable )installs from an MSI) that should let me list the ports, disable and enable each one, one at a time.
    Thantos Im running Frodoplayer, but this app runs outside the frontend.
    '02 GTI
    Nov 2004
    Well this happened to me before and the problem is with the build in backing camera app... just go to settings and disable or change the port to a higher number.
    also default for XM is port 3 but check that is no using COM 1 as well.
    Thanatos.
    Nissan Aux-in MOD
  1. Replies: 7
    Last Post: 03-04-2008, 10:16 PM
  2. Replies: 6
    Last Post: 03-27-2006, 04:52 PM
  3. cant figure out the keys
    By vicky_obee in forum PowerVoice
    Last Post: 06-18-2005, 09:01 PM
  4. Replies: 7
    Last Post: 02-26-2005, 06:09 AM
  5. Replies: 12
    Last Post: 09-23-2004, 02:00 PM
