Results 1 to 9 of 9
Thread: Custom Case - All In One Connector.. Suggestions?
    Aug 2006
    Hi all,
    I'm going to be fabricating a custom case for my car pc (currently a laptop) and on the backplane of the case I'd like to get a single connector and have everything on there, then in the car just have a single connector that fits onto it.
    I've worked out I need around a 20 way connector to get everything wired up.
    Also on the connector in the car I need the cables to exit at 90 degrees so when the connector is fitted (will be vertical) the leads exit the connector downwards into the boot..
    So far I've only managed to come up with the possibility of using a scart connector (http://www.maplin.co.uk/Module.aspx?...=43116&doy=3m7), but I don't know if this will be rated enough to carry power etc.. (laptop runs around 15v 5a max)
    Anyone got any suggestions for this? the connector need to be as compact as possible.
    Cheers
    Mar 2007
    You could search Molex, Samtec, Tyco/AMP, Digikey, Mouser, etc. for millions of different connectors that would work.
    The datasheet for the connector should tell you how much current each pin can handle. The one in your link didn't though... I would guess around 1A per pin, so power alone would need 5 pins).
    However, I suggest you either start with a real docking station for the laptop, or live with only 2 or 3 cables. With a USB hub and a USB sound-card you should have only Power, USB, and VGA to connect. With a USB VGA-Adapter you could get it down to only 2 (or even USB-only when the laptop is already charged).
    Nov 2006
    Gloucestershire, UK
    Nice idea, but do you really need this? It's going to be vunerable to problems, such as, you'll need to turn everything off when you plug it in, because the pins could strike against other pins.
    Nice intentions, bad idea.
    Aug 2006
    Do I need it? No.. probably not, but its something I definatley want to attempt anyway.
    At the moment I've got a laptop sat in my boot with the following coming off the back; 2x usb, 1x vga, 1x line out, 1x charger plug, 1x serial - basically it looks a freakin mess! so I'd like to give it a tidy up.
    I'll only ever be plugging it in with everything off anyway so shorting shouldn't be a problem (hopefully!)
    Thanks Newb77 for the pointers on manufacturers for these type of things.. I will have a search around
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    If you do plan to make your own all in one connection, just make sure that you are using the right gauge cable too, small cables don't hold high current well. And the further the distance it goes, to bigger the wire needs to be. Just a caution.
    You're probably better off just using zip ties and tape, and conceal the bulk of the mess inside the case you make for it.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Newbie mobes's Avatar
    Sep 2001
    Leander, TX
    How about using an ATX extension? Cut it in half and you've got yourself mating connectors with pigtails.
    Aug 2006
    Quote Originally Posted by mobes View Post
    Now that is a bloody good idea... why the hell didn't I think of that
    Newbie neilhart's Avatar
    Jan 2006
    Fremont, CA
    RS-232 25 pin connectors and cables
    You might consider using a db-25 sub connector. These are relative inexpensive and you can use 25 pin serial cables for the run. I would not put power through these, but are great for running signal lines in the car and provide easy reconnection.
    You can look at my project at www.sfba-corvette.com to see how I placed a remote control panel in the center console.
    Neil.
    neilhart
    aka Neil
    My Domain is www.sfba-corvette.com check it out!
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    i would separate the power wires you don't want interference
  1. Custom Case for Mini-ITX PC
    By birdie in forum Fabrication
    Last Post: 02-08-2007, 04:26 AM
  2. truckputer sale including custom frontier case!!
    By jaymx211 in forum Classified Archive
    Last Post: 10-21-2005, 11:33 PM
  3. Painting Ampie Case
    By semovodka in forum General MP3Car Discussion
    Last Post: 10-08-2005, 05:37 PM
  4. Making a custom case..............??
    By brandondere in forum General MP3Car Discussion
    Last Post: 01-11-2001, 08:17 AM
  5. some pictures of my car and custom case
    By Awol][ in forum General MP3Car Discussion
    Last Post: 12-07-2000, 09:04 AM
