Results 11 to 20 of 27
Thread: lcd view all day and night?
  1. #11
    Variable Bitrate Borte's Avatar
    Jan 2006
    Norway
    Quote Originally Posted by archaic0 View Post
    I think maybe instead of an overlay piece, I might see if I can't cut a slit on the top part of the screen case and slide in a tint sheet at night like you put a gel in front of a spotlight. Maybe that's an idea...
    I did this originally (placed the film in front of the screen) but the film (thit sheet in your case) got scratched and worn after a while. That's the reason why I placed it between the touchplate and the screen.
    Failure is not an option...
    _________________________________________
    The open source C# Front End -> OpenMobile
  2. #12
    Constant Bitrate archaic0's Avatar
    Jan 2007
    McAlester, OK
    Well if I do the slide in filter thing maybe I'll be able to slide it between the touchplate and the screen.
  3. #13
    Jan 2006
    Norway
    I don't think thats possible without opening the screen up. It's usually glued together.
  4. #14
    Newbie Dingo509's Avatar
    Aug 2005
    Washington, USA
    Im still learning what can and cannot be done. but it is possible to somehow wire a resistor or something similiar into the light tubes? maybe put them on a switch with the normal voltage on one side and the reduced power on the other?
    It may be PWM too but you should be able to find out how to reduce that to decrease the backlight.
    I think?
    Dingo
    Progress: Installed and working. Needs some cleanup and trim work done. now for complete integration.
    91 Jeep Cherokee 8" custom lift, 3/4 ton running gear 36" swampers, Snorkel, Onboard air, Onboard Shower. Now with in dash PC!
  5. #15
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    There have been a few threads on this over the years. From what I remember, the inverter puts out around 600 to 900 volts and very little power/amps. You need to lower the volts without decreasing amps or frequency. Otherwise you shorten the life span. On my lilliput, I traced the inverter source power and tapped into it, then connected it to the dash dimmer through a relay.
  6. #16
    Jun 2007
    Polairs (Lewis Center) Ohio
    wow wtf
    Quote Originally Posted by tonystoolroom View Post
    I wonder what a 8" Data911 screen costs?
    http://www.data911.com/main/display.html
    Just got off the phone with them $2,585 for lvds display only, that is for the 8.4
  7. #17
    Jun 2007
    I know most LCD displays use Cold Cathode fluorescent lights as the backlighting nowadays, but I've pondered using a material similar to the Indiglo material... Electroluminescent plastics. They can be dimmed much easier than CCF tubes. The coupld of LCD's I've opened all had a sheet of Lexan type material to distribute the light from the tubes at the sides of the panel to the entire panel. You should be able to just replace the Lexan with the electroluminescent plastic material and wire it up.
    LED's wound be another option... Replace the CCF with a strip of surface mount white LED's controlled by a PWM circuit.
    Of course, the ideal solution won't be available for another couple of years, but that is Organic LED displays. I was hoping the IPhone might use OLED technology, but it's not quite there yet. OLED displays will be able to be dimmed down as dim or bright as you need because there will not be a backlight. The display itself produces the light, just like the phosphors on a TV.
  8. #18
    Jan 2007
    McAlester, OK
    The inverters usually are really high voltage, that's correct. Some soar upwards of 10,000 volts actually. And some even have some pretty big draws like 2 to 3 amps. Sounds small, but milliamps are enough to kill you if they hit your heart, and brain frying electoshock is done with less than an amp too. *smile*
    I could try to find the inverters source power and try wiring in a rheostat there to drop it's input voltage with a knob. That would probably effect it's output voltage, but whether or not that would change the resulting brightness of the bulb is another story. I don't know just what technology the bulb is, but fluorescent are not dimable by voltage. you can't just wire in a dimmer switch like you can with incandescents. Recently they have been able to dim fluorescents, but it's by way of blinking the power on and off very quickly to 'fake' a dimmer light.
    Has anyone actually wired in a knob and had it work or are we all just brainstorming?
    For now, I'm just going to make an overlay with some stout wire and hang a tint film over top of the screen at night. Exactly how I'm going to do that is yet to be figured out. I need to solve a couple issues for it to work.
    1. How do I make the tint stiff enough to hold it's shape? The tint is very loose just hanging out by itself. Either I find a way to stretch it and make it work, or I find a thin base piece of glass or plastic and tint that piece.
    2. How do I attach this to the screen? I could just hang it, but it might need something stronger. Velcro might be an option. It needs to be able to come on and off quickly.
    3. Where do I put this overlay during the day? If it doesn't have an assigned place and holder, then it's most certainly going to get broken or lost.
    4. In the end, is the new solution better or worse overall than the bright light? I don't want to diminish my CarPC experience, so whatever solution I come up with needs to not get in the way of me using and enjoying my system.
  9. #19
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    I don't know if it would help you enough, but my 3M privacy filter cuts down on interior glowing quite a bit due to the narrow field of view.
  10. #20
    Jan 2007
    McAlester, OK
    That's a thought... even if I have to get one and cut it down to size that might be better than the tint.
  1. Onyx Day appears as Onyx Night in 1.12?
    By birdie in forum CF Bug Reports
    Last Post: 05-03-2007, 05:24 PM
  2. Changing Day to Night skin
    By seninha in forum Road Runner
    Last Post: 11-11-2006, 01:12 PM
  3. Best Way to Distribute a Skin (Night / Day)
    By thunderdepot in forum Road Runner
    Last Post: 08-19-2006, 09:50 AM
  4. Night / Day Skin Code:
    By IntellaWorks in forum Coders Corner
    Last Post: 01-06-2006, 03:58 PM
  5. night skin day skin problem.
    By fallnangel in forum FrodoPlayer
    Last Post: 02-02-2005, 09:08 AM
