Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: how do you guys build "racks" to keep case small?
    Mar 2007
    I'm currently building my own case and to make everything small enough I was wondering how do you guys fabricate "racks" or any kind of things to hold a hardrive up above the motherboard.
    what is the easiest and strongest way?
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Aluminium sheet.
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Yeah, sure, follow Rob's way if you want strongest... but nothing beats duct tape for easiest! You do it right, it can hold up for as long as you have the car.
    Mar 2007
    aluminum sheet, like those little pieces at home depot? that stuff is not cheap. 12 dollars is the minimun I think. Wouldn't it be easier to use maybe the "corner" pieces? and just cut them to length?
    this does give me more ideas so thankyou,
    Mar 2007
    Surrey, BC
    you could also mount hard plastic. you'll just need to use a strong enough adhesive/silicon
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by Snortonnorton View Post
    I use offcuts from aluminium project boxes, it's not very expensive.
    If you like. It's your case, do it your way.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Be creative. Use whatever you had/found. I screw mine directly to the plexi case.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2006
    Colorado, but Canadian!
    laser cut acrylic.
    1.9in x 2.9in -- 47mm x 73mm
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    I screwed mine to the Lexan.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Mar 2007
    i took the be creative route.
    took aluminum bar stock and screwed them to the inner walls with L shaped brackets I already had for box construction.
    they even swivel for moving around during wiring and perhaps shock support? doubtul but super easy to fabricate up.
    now I just have to remove my seat that I already raised just to test fit the box.
    call me cheap, but I had a spare ATX board so with a fast cpu and 1 gig of ram, so why buy a mini ITX?
    Shot with Canon PowerShot A410 at 2007-07-06
  1. Painting Ampie Case
    By semovodka in forum General MP3Car Discussion
    Last Post: 10-08-2005, 04:37 PM
  2. A heatsink case for small PC (like a power amp style)
    By phoTToniq in forum General Hardware Discussion
    Last Post: 08-27-2003, 10:15 AM
  3. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 09:42 PM
  4. Cool looking case for fv24
    By B3AND1P in forum General Hardware Discussion
    Last Post: 04-20-2002, 11:28 AM
  5. My first design and build - need advice from you guys.
    By Griffin_Dodd in forum General Hardware Discussion
    Last Post: 02-02-2002, 12:04 AM
