this is in the wrong section, probably why you haven't gotten an replies.
basically the dac has 2 outs from there you can go to an active x-over (thats what i did) and then that'll 'steer' your audio signals to the right amp chans. (lows to your sub, highs to your door speakers). if you're fortunate enough to have an amp that has line level outputs and a decent internal crossover then you may be able to skip the active crossover and just go from the dac to the amp.
another option, if your amp(s) have internal x-overs is to get a rca y-cable to get 4 outputs from the dac and then set your x-over points on the amp.
LinkBack URL
About LinkBacks
