You may want to check that the BIOS isn't set to turn back on after a power failure. It could see your power up attempts as a power failure if you aren't shutting the system down. Or try to let the system boot completely into the OS and then shut it down. Apply power after that and see if it turns on.
LinkBack URL
About LinkBacks
