Yep, I did something similar, pictures on my site.
Rob
All i've got in my Hyundai is a stock head unit. I was wondering if I could hack the audio lines going to the speakers so that I could place a switch to select between the head signal, and my mp3 player signal. I don't think the computer will put out a good enough level so I'm going to build a buffer/amplifier to give it some more gain. Would this be more trouble than it's worth? Should I just get a tape adaptor? Anyone done this before? pics?
Michael
Rob
Rob
... thought I'd let you know (you must be using css) that on your website your pictures are covering up a lot of your text.
Thanks for letting me know. I'm using hand written html ("Site created with Notepad...!"). I don't see any problems on my machine. What browser are you using?Originally posted by ddt
Rob
What browser are you using? I'm using IE 5.5 and it looks fine.Originally posted by ddt
[------------------|--] 90% Completed
Not installed, yet.
Developing Completely DirectX shell.
P4 1.7GHz, 256MB RAM, 40GB-7200RPM HD
Rob
I've shrunk the thumbnails anyway, hopefully that'll help a bit, whatever the problem is.
Rob
IE 6.0 .. but maybe it's just the browser.. I'll check it out with netscape 7.
by the way... it's the hardware page I'm refering to.
For example on the hardware page see the heading "The Control Unit (Mk 1)?" Look at the two pictures side by side below it. Don't you see the text under them?
***LOOKS LIKE YOU FIXED IT***
Cool. I'm guessing you are running at some insanely low resolution.Originally posted by ddt
If you take the current page and squash the window a lot horizontally, you can get the pictures on top of the text, but you have to go very low res to make it happen.
Rob
Yeah, I also had that problem, IE6 1024x768. Seems to be fixed now, though.
(=========-) 99% complete
AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
All jammed in external CDROM drive case.
Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
