Okay i have a 133mhz laptop that i really want to use for my mp3 player. I just have a few quuestions:
1- I plan on using a 2x16 lcd display but am not sure how i will power it other that putting a power supply in my car.
2- I want to put the computer in my trunk so i am not sure how I am gonna turn it on and off without going in the trunk??
2 - I want to get a portable hard drive for it so i can easily put files on. The problem here is that i really want to make it DOS bassed and i think most of these are usb. I know some are parell but i need that for the lcd and i need the serial port for the irman.
Thanks ahead for all your help.
A 97 Dodge Ram pickup with a 14" LCD running at 1024x768. A Dell desktop PII 400, 128MB Ram, 8GB & 20GB Drives, TV tuner, Cd Burner, Garmin legend GPS, Mappoint 2002, win98, and winamp.
pics
1) - you can get 5v off of the ps/2 port. Just cut up an old mouse or keyboard cable and look for it.
2) He is correct, i just soldered a momentary push button onto mine.
3) I have several un-used 2gb toshiba PCMCIA hard drives, if you are interested in purchasing one.
Car: 1999 Dark Green Mustang GT Coupe
Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
Player: Empeg for now; something custom later.
www.neotechpc.com - Custom built laptops!
the ps2 port will work for power, although if you didnt want to run lines from the trunk, if you had/found/made a 12v to 5v lcd converter you could power the lcd from the car power at the front of the car.
also, some 2x16 lcds can take a range of voltage, so find out what yours can take.
although, if it says 5v only, make sure it only gets 5v. i was installing a 2x16 char screen on the front of my computer case, and i hooked it up to 12v by accident, and its busted now. it made some of the green back light leds turn red though.
smashr2k
How much do you want for the 2gb PCMCIA
and will you ship to Scotland?
