Results 1 to 3 of 3
Thread: problem with GPS mouse
    Jul 2004
    Essex
    Ok here it goes got a USB gps mouse
    Plug it into my 5v powerd USB hub
    Inside this hub is
    A ODB2 reader ( uses a USB>serial interface) COM5
    a USB bluetooth
    and then this GPS mouse
    i install the drivers all is ok ... picks up all my sats etc in centrafuse ...
    in hardware manager the driver is called Profile USB > serial ( or somin liek that) and it on COM6
    But .. as soon as i restart the PC and windows reloads it dosnt work .. my bluetooth constintly turns on and off
    my wireless which aint even in the Hub is not reconised
    ,.... then as soon as i uninstall the drivers everything works correctly again !
    Im stumped for ideas n e 1 ran in 2 this proble be4 ?
    Jul 2004
    Essex
    ok unplugged bluetooth and installed Gps and it works fine..
    i m thinking i might be a hub issue as some hubs dont like some things conncted in 2 it...
    im gonna try it in a diff port and c what happens , a port tht aint on the hub
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    I have run into problems in the past with things running off usb hubs when their close to drawing the hubs full power. the hub would just stop working. I would plug one of the devices into a normal usb port and everything works fine. I think there is also can be a problem when you run usb1.1 and usb2.0 devices on the same hub.
    Worst come to worst, try the gps receiver on its own usb port.
  1. problem with gps mouse ad map monkey
    By pijo1971 in forum GPS
    Last Post: 10-14-2005, 02:24 AM
  2. FS: Deluo GPS mouse and Routis 2004
    By ayclens in forum Classified Archive
    Last Post: 09-16-2005, 01:33 PM
  3. Replies: 1
    Last Post: 01-03-2005, 06:05 PM
  4. GPS not found problem
    By ThEScReW in forum GPS
    Last Post: 12-20-2004, 06:39 PM
  5. Problem with GPS probably voltage
    By GReeToZ in forum General Hardware Discussion
    Last Post: 10-26-2004, 02:26 PM
