Results 1 to 10 of 12
Thread: Ac Blowing on Computer
    Variable Bitrate Area3's Avatar
    Mar 2007
    Garland, Texas, United States
    Howdy Yall
    I am looking at Purchasing a Voom Pc Case for my carputer and I had a Couple of Questions....
    I want to mount it under my seat but there is a Ac Vent down there...
    Is it ok for the ac vent to be blowing on the computer?
    Microsoft Is a Evil Empire that has corrupted a generation!
    Thanks - Eric Scott
    Area 3 Productions
    www.myspace.com/area3
    Jan 2007
    Warner Robins, GA
    I can't see a reason why not. I actually routed a vent in my setup to blow on the hard drive and CPU. The A/C should be blowing cool, dry air, which is a good thing. I'm not sure about blowing heat on it during the winter though, so maybe someone else has some insight. That's the only problem I can personally foresee.
    Mar 2007
    Thats the only problem Im seeing Is the heat....
    Although in Texas We dont see much cold
    Thanks - Eric Scott
    Area 3 Productions
    Jan 2007
    Warner Robins, GA
    True enough, I'm from a small town east of Dallas called Wills Point, maybe 60 miles from you so I know exactly what you're talking about, and Georgia is about the same
    Mar 2007
    Do you think the heat blowing on the Carputer would be beneficial?
    Thanks - Eric Scott
    Area 3 Productions
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    heat with electronics = PROBLEM!!!!
    Extra cold with physical parts = PROBLEM!!! (Hard Drive)
    Blowing AC on a computer isnt a bad thing, what you should do it's get a board that you can install a smale utility that can sens the temperature of your CPU. Unfortunatly you won't be able to know what you HardDrive temp is.
    In my area I have both high and Low temp so I must be carefull with this and take as much precaution as needed....
    advice = take your time and run some test before final install...!!!Good luck and keep us updated!
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    Jul 2007
    I would say the best bet is to keep your computer at approximately the same temperature as your cabin. Blowing the AC on it during the summer can help cool it off quickly from 104F, but most computers are meant to be operated at room temperature. Slightly above or below is okay, but you don't want 40F air blowing on your computer. That can cause condensation. You also don't want 90F air blowing across it during the winter.
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    If the vent is on the floor, does it only blow when you put the vent control on the feet setting? If so, you at least have the ability to not push cold (or hot) air out entirely.
    Mar 2007
    No It Just blows lol
    I doesnt matter if it is feet or anything?
    Thanks - Eric Scott
    Area 3 Productions
    Mar 2007
    Central Florida
    I don't think it's a good idea. If it's really humid outside, water can condense on the computer, as soon as you turn off the car and open the door. This will happen inside the unit too, since it draws the water, straight from the air. It shouldn't be a problem while the air is blowing, only after you get it really cool. In the winter, I'm not sure it's that big of a deal though, because you're probably only running the heat when it's cold outside, thus just counteracting the cold. And heat rises. Of course, it depends on how hot the air is, how close it is, how cold it is outside and of course the seat can perhaps trap the warm air down there.
    Like someone else said, the definitive way would be to make some measurements, but personally, I would either disconnect that duct somehow or relocate the computer. Just my $0.02.
  1. Computer Crashed?
    By Rocky388 in forum General Hardware Discussion
    Last Post: 11-30-2005, 09:39 PM
  2. Computer PSU (AC) to Power Opus
    By Jcarere in forum Power Supplies
    Last Post: 11-17-2005, 06:44 PM
  3. Replies: 5
    Last Post: 11-08-2005, 09:04 PM
  4. computer theft tracking - PC PhoneHome
    By Question in forum General MP3Car Discussion
    Last Post: 07-16-2003, 02:14 PM
  5. controling ac system with car pc
    By sugarmychurro in forum General Hardware Discussion
    Last Post: 05-21-2003, 01:17 AM
