Page 12 of 16 FirstFirst ... 2345678910111213141516 LastLast
Results 111 to 120 of 154
Thread: Core Duo / Core 2 Duo Mini-ITX boards
  1. #111
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    You pay for what you get
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  2. #112
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by danielkh View Post
    Plus CPU and RAM. lol
    Still, that is one nice board. 10 USB ports, onboard video, 7.1 onboard audio, I bet it would kick butt. It's like the Kino on serious steroids. Bet you would have ZERO configuration or USB errors with that one.
    It's not much different from my DG45FC, only it uses a mobile processor and has firewire.
    Which are the two critical things making me want to change boards...lol
    Wonder if you can underclock via the bios....
    Jan Bennett
  3. #113
    Feb 2007
    netherlands
    Quote Originally Posted by RedGTiVR6 View Post
    Are you having power isues? BEcause when i look to the voltmeter in the car, the cpc does't use that mutch you don't see the meter drop. But whe the amps swith on you do see a drop in volts. But still one heated seat uses more.
    I ditched my commel because of the cold wheater problems i had with it and also the warrenty wasn't as long as the intel.
  4. #114
    _
    Mar 2004
    Little Elm, Texas
    I'm not having power issues.
    Keep in mind that what I use a CarPC for is extreme sound quality reproduction.
    A desktop processor generates a lot more heat than a mobile processor does.
    This means more current draw through the system AND the requirement of a louder fan than a mobile processor. To boot, with a mobile processor, I can actually underclock it (if the board allows for it) and can run it with only passive cooling for short periods of time (aka judging).
    Extreme cold weather isn't so much of an issue down here. A few days will drop to the teens, maybe a single digit here or there, but nothing like what they get up north.
    For me, HEAT is the main concern as 115 degree days during the summer can and have been the norm for a month straight.
    Jan Bennett
  5. #115
    Nov 2008
    Stockholm
    Go for Intel ATOM
    If you want a board that runs fast without generating much heat, you should go for Intel ATOM or Via Nano, then we talking 2-5 Watt for the cpu.
    Kontron - ktus15mitx
  6. #116
    Feb 2007
    netherlands
    I know, because of your ppost on the sound of this board i got it too. Even the U46mk2 (dj soundcard) didn't cut it) the sound of the dg45fc is like the head i had. Low on the dls fronts .
    its a litle of topic, But i use a Zalman CNPS8000 cpu cooler with the lowest fan speed. It has 3 wires, so the dg45fc can't controle the fanspeed.
    I did have to modify the X-bracket, but after that it works and fits like a charm.
    (i'll update the worklog with the pictures, thought the X-braket is already on the forum in a dg45fc thread).
  7. #117
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by dangs View Post
    That would be great and all....but they don't fit my needs. I don't just need a motherboard, I need a motherboard with certain features.
    Don't have room for a full height CPU cooler. Must use a 1U cooler. I had to modify my X-bracket as well.
    Jan Bennett
  8. #118
    _
    Mar 2004
    Little Elm, Texas
    So i requested a quote....this is pretty good:
    GLOBAL'S RESPONSE
    Our Integrated mini-ITX Motherboard Assembly will consist of the following:
    • Our mini-ITX Motherboard P/N 2808100 - with Integrated 9V ~ 24V full range DC input DC/DC Converter on board, ATX power connector on board, 1-mini-PCIe socket, 1 X mini-PCI socket, 1 X PCIeX16 slot, etc., etc.
    • Cable Kit, I/O Shield and CD ROM Media with Manual and Drivers.
    • Intel MOBILE, Socket P, CORE 2 DUO, T9400, 2.53 GHz CPU with 6.0 MB L2 Cache and 1066 MHz FSB
    • Low Profile DEDICATED COPPER CPU Cooling Assembly.
    • 1.0 GB DDR3, PC3-8500 SDRAM
    • *The Assembly will be integrated , tested, stressed (PASSMARK BURNINTEST Version 5.3) and subjected to8 hours minimum of DYNAMIC burn-in and a Certificate of Compliance to test will be attached to each unit.
    The unit carries 12 month warranty for all the components FROM JUST ONE SOURCE - GLOBAL AMERICAN, INC.
    Quantity 1-9 -$ 1099.63 each
    Quantity 10-99 -$ 1058.57 each
    DELIVERY - ALL the Components are within 10 working days ARO (These can be expedited at an EXTRA CHARGE)
    The Fully Integrated, Tested, Stressed and Burnt-in Assembly will be NLT 17 working days ARO (These can be expedited to NLT 10 working days ARO at an EXTRA CHARGE of NTE$ 50.00 for up to 2 Assemblies)
    Jan Bennett
  9. #119
    Feb 2007
    netherlands
    The atum boards still have one problem. The chipset needs a lot of power.
    In idle it just uses 10 wats las than the dg45fc with a E8500 processor lower processors use 5 watts less.
    Yes with full load it will use more power. But full load for the atum isn't full load for the dg45fc.
    Also the sound options for the atum boards was a little les than the dg.
  10. #120
    Mar 2007
    Socal
    [/font][/b][/b][/color][/color]
    That's Global for ya! They treated me pretty good and I can speak highly for their resident engineers (assuming they're still employed).
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. mac mini core solo enough for bootcamp?
    By replicant in forum MacCar
    Last Post: 06-26-2006, 11:49 PM
  3. Replies: 7
    Last Post: 07-19-2005, 05:24 PM
  4. MINI atx or Itx
    By JDTUNER in forum General Hardware Discussion
    Last Post: 06-01-2005, 10:31 PM
  5. Where to Purchase Jetway ITX boards?
    By SuperMatty in forum Classified Archive
    Last Post: 05-25-2003, 11:21 PM
