Page 13 of 16 FirstFirst ... 345678910111213141516 LastLast
Results 121 to 130 of 154
Thread: Core Duo / Core 2 Duo Mini-ITX boards
  1. #121
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Quote Originally Posted by rijk View Post
    The atum boards still have one problem. The chipset needs a lot of power.
    In idle it just uses 10 wats las than the dg45fc with a E8500 processor lower processors use 5 watts less.
    Yes with full load it will use more power. But full load for the atum isn't full load for the dg45fc.
    Also the sound options for the atum boards was a little les than the dg.
    This is true. Many Atom boards use the 945 chipset, which is ancient and was also designed before anyone cared about "green".
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  2. #122
    Nov 2008
    Trying to get difference between Global and LV-67B looks like same board and configured with same CPU/RAM COMMELL's is about $280 cheaper.
    On the other hand - I need to find a board which could house full size PCI card(Lynx 22)but might get away with PCI-E Lynx AES16e. Then I needto find case which can host it .
    BTW any opinion on VIA Nano chips/boards
  3. #123
    Mar 2007
    Socal
    Global sells rebranded Commells, so it is the same board.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  4. #124
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon
    Quote Originally Posted by RedGTiVR6 View Post
    So i requested a quote....this is pretty good:
    [/FONT][/B][/B][/COLOR][/COLOR]
    That's a good number. If you go that way, I would love to know how it works. Can't justify it with having the Kino, but I would like to know for future reference. Especially interested in the ACL888 sound(you're not going to use that, are you. lol)
    Do they still make the peltier coolers? That might work well for you if they do. Small strip that gets really cold on one side while releasing the heat on the other? The one I had back in the early 90's worked really well. Went between the CPU and fan and didn't add that much to the height. Not sure how they would work in a mobile environment though.
    My opinion is my own.
  5. #125
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by danielkh View Post
    Plus CPU and RAM. lol
    Still, that is one nice board. 10 USB ports, onboard video, 7.1 onboard audio, I bet it would kick butt. It's like the Kino on serious steroids. Bet you would have ZERO configuration or USB errors with that one.
    Which KINO are you talking about? The KINO-690S1, or a INTEL version? The AMD version is really fast, uses laptop RAM (so doesnt take up space). It has 8 USB ports, but they are picky with what gets plugged into them, it took me a long time to finally get everything working good. Audio is so cr@ppy, for this being a suppossed highend multimedia board, only have a stereo line out and a mic in port is rather cr@ppy. Graphics wise this board is amazing, I love the graphics and how it renders 3D so easily (have arcade games on it). Bad thing is that they only put a passive heatsink, so the GPU overheats easily. I had to add a fan to it. This mobo runs on SATA, with 1 IDE port (which I dont use) and 4 serial ports (I use these for Sirius XM, OBD2 scanner, Amp_Ctrl, and HD Radio).
    I love this board alot that I was willing to deal with the USB and overheating issues. The downfall is that it seems to be one of the only AMD boards I could find, and alot of sites are not carrying it anymore. I recently had to RMA the board from the GPU blowing out (was my fauly though, not from over heating). Im worried that in the future I wont be able to RMA it anymore, but I guess that happens with all technology.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  6. #126
    Sep 2007
    Beaverton, Oregon
    Quote Originally Posted by HiJackZX1 View Post
    Kino-9452 with the 7.1 HD Audio. (Intel version with 6 back audio ports and 2 front)
    I would put the audio on this board against any USB and most (Don't jump on me Jan, I said MOST! lol) PCI soundcards. Since it's onboard, there aren't any configuration issues that I have found and has extreme controllability.
  7. #127
    _
    Mar 2004
    Little Elm, Texas
    danielkh - you know I don't use onboard analogue outputs, right? Never have and never will. Don't even recomend them as they sound HORRIBLE.
    Onboard optic is a different situation.
    If I DO go that route, then I'll be running optic into the Alpine for the time being...hopefully that will change soon though.
    Jan Bennett
  8. #128
    Feb 2007
    netherlands
    For me, HEAT is the main concern as 115 degree days during the summer can and have been the norm for a month straight.
    If you change boards this quickly, maybe my old position of the mobo is a solution for you. My board had to mutch cold on that position.
    (engine bay see worklog for the pictures)
    @ sh** forgot to test the boottime
  9. #129
    _
    Mar 2004
    Little Elm, Texas
    I'm not sure I understand your post. Are you saying that I should consider putting a CarPC in the engine bay of my car?
    Jan Bennett
  10. #130
    Jul 2007
    Miami
    What car is this for? The GTi or your Dodge? I know this is drastic, but maybe instead of having, whatever car its in, 5 seats, drop it down to 4 seats and build the middle seat into a center console that holds the PC. Mine is like this and has 2 large fans in the front that pull large amounts of air in and 2 in the back that pull the air out. My front console also has fans that pull the air in and out and by a thing of luck, when the A/C is on, the front console sucks in the A/C air, then blows it out the back of it, where then the second console gets that air, sucks it in, cools the P/C and then dumps the air out the back. It has worked very well so far.
    4x 10inch Tablet
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. mac mini core solo enough for bootcamp?
    By replicant in forum MacCar
    Last Post: 06-26-2006, 11:49 PM
  3. Replies: 7
    Last Post: 07-19-2005, 05:24 PM
  4. MINI atx or Itx
    By JDTUNER in forum General Hardware Discussion
    Last Post: 06-01-2005, 10:31 PM
  5. Where to Purchase Jetway ITX boards?
    By SuperMatty in forum Classified Archive
    Last Post: 05-25-2003, 11:21 PM
