MSI Industrial GM965 Core 2 Duo Mobile Mini-ITX Mainboard
This should interest quite a few people!
In the past few weeks, a new mini-ITX Socket P motherboard was introduced, which will make it much easier for upgrading with Intel's future processors (and it's cheaper for a socket P processor). I just purchased the Core 2 Duo T7300 from newegg, along with this MB from logicsupply.
Anyway, here are the details:
MS-9803 Specifications
Processor
Core 2 Duo Mobile (Merom)
Socket P (478 pin) 800 MHz FSB
Chipset
Intel GM965 Northbridge
ICH8M Southbridge
System Memory
2 DDR2 533/667 SDRAM sockets
Up to 4GB (recognizable...3.25GB) memory size
VGA
Built-in Intel Graphics with GMA X3100 Technology
Expansion Slots
1 PCI Express (x16)
1 PCI (32-bit)
1 PCI Express Mini Card
Onboard IDE
1 ATA 100 (40-pin)
Onboard Serial ATA
2 SATA II connectors
CompactFlash
CF slot on bottom
Onboard USB
8 USB 2.0
Onboard LAN
1 Intel 82566DC 10/100/1000
1 Intel 82573L 10/100/1000
Onboard Audio
ALC888 7.1/5.1 channel HD audio codec
Back Panel I/O
1 PS2 mouse port
1 PS2 keyboard port
1 VGA port
1 RS-232 COM port
2 LAN ports
4 USB 2.0 ports
6 Audio jacks: line-out, line-in, mic-in, rear surround-out, center-/subwoofer-out, S/PDIF-out (optical)
Onboard I/O Connectors
1 IDE slot
1 LVDS connector
1 DIO connector (16 GPIO)
1 RS-232 COM connector
1 Parallel port connector
1 S/PDIF connector
2 SATA connectors
1 TV-out connector
2 USB 2.0 connectors for 4 USB ports
1 Front panel connector
1 Amplifier connector (4-pin)
2 Fan connectors
ATX power connector
BIOS
Award BIOS 4Mb flash memory
System Monitoring & Management
Watchdog timer, CPU voltage monitoring, CPU temperature monitoring, Fan control, Wake on USB, Wake on LAN, Wake on Ring, System power management
Operating Temperature
0 ~ 55°C
Operating Humidity
0% ~ 85% (relative humidity; non-condensing)
Form Factor
Mini-ITX (17 cm x 17 cm)
