Page 4 of 16 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 154
Thread: Core Duo / Core 2 Duo Mini-ITX boards
  1. #31
    Low Bitrate nationapn's Avatar
    Jul 2007
    Randolph AFB, TX
    MSI Industrial GM965 Core 2 Duo Mobile Mini-ITX Mainboard
    This should interest quite a few people!
    In the past few weeks, a new mini-ITX Socket P motherboard was introduced, which will make it much easier for upgrading with Intel's future processors (and it's cheaper for a socket P processor). I just purchased the Core 2 Duo T7300 from newegg, along with this MB from logicsupply.
    Anyway, here are the details:
    MS-9803 Specifications
    Processor
    Core 2 Duo Mobile (Merom)
    Socket P (478 pin) 800 MHz FSB
    Chipset
    Intel GM965 Northbridge
    ICH8M Southbridge
    System Memory
    2 DDR2 533/667 SDRAM sockets
    Up to 4GB (recognizable...3.25GB) memory size
    VGA
    Built-in Intel Graphics with GMA X3100 Technology
    Expansion Slots
    1 PCI Express (x16)
    1 PCI (32-bit)
    1 PCI Express Mini Card
    Onboard IDE
    1 ATA 100 (40-pin)
    Onboard Serial ATA
    2 SATA II connectors
    CompactFlash
    CF slot on bottom
    Onboard USB
    8 USB 2.0
    Onboard LAN
    1 Intel 82566DC 10/100/1000
    1 Intel 82573L 10/100/1000
    Onboard Audio
    ALC888 7.1/5.1 channel HD audio codec
    Back Panel I/O
    1 PS2 mouse port
    1 PS2 keyboard port
    1 VGA port
    1 RS-232 COM port
    2 LAN ports
    4 USB 2.0 ports
    6 Audio jacks: line-out, line-in, mic-in, rear surround-out, center-/subwoofer-out, S/PDIF-out (optical)
    Onboard I/O Connectors
    1 IDE slot
    1 LVDS connector
    1 DIO connector (16 GPIO)
    1 RS-232 COM connector
    1 Parallel port connector
    1 S/PDIF connector
    2 SATA connectors
    1 TV-out connector
    2 USB 2.0 connectors for 4 USB ports
    1 Front panel connector
    1 Amplifier connector (4-pin)
    2 Fan connectors
    ATX power connector
    BIOS
    Award BIOS 4Mb flash memory
    System Monitoring & Management
    Watchdog timer, CPU voltage monitoring, CPU temperature monitoring, Fan control, Wake on USB, Wake on LAN, Wake on Ring, System power management
    Operating Temperature
    0 ~ 55°C
    Operating Humidity
    0% ~ 85% (relative humidity; non-condensing)
    Form Factor
    Mini-ITX (17 cm x 17 cm)
  2. #32
    Jul 2007
    Randolph AFB, TX
    Here's a picture of it:
  3. #33
    Feb 2006
    Melbourne, Australia
    Nice looking board, with a good feaure-set. Thanx for the heads-up! My LV-677 could certainly have done with a few more onboard USB ports
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  4. #34
    _
    Mar 2004
    Little Elm, Texas
    Added the MSI Fuzzy 965
    Jan Bennett
  5. #35
    Sep 2005
    No PCMCIA slot?
  6. #36
    Jul 2007
    Randolph AFB, TX
    No...That's the only drawback I could see. I guess that just keeps from being able to use a PCMCIA slot for extra USB 2.0 ports (but the board supports 8), a PCMCIA broadband modem, or a sound card.
    The positives definitely outweighed the negatives for me, especially being a socket P. Also important to note are that the built-in audio and video are excellent, and there is a PCI-E slot built in, so it's not like expandability is impossible.
  7. #37
    Sep 2005
    Quote Originally Posted by nationapn View Post
    Interesting. Will mp3.com be selling CarPCs with this mobo installed and if so, ETA?
    I wonder if I could get XenarcDirect to put it in my SC-10...
  8. #38
    Feb 2006
    @ RedGTiVR6: You may want to add the new Commell LS-372 to your list, it is a very nice, and compact 3.5" Socket-P board.
    It will be available mid-October, according to one industrial supplier in Australia.
  9. #39
    _
    Mar 2004
    Little Elm, Texas
    I'm going to try and keep this thread for mITX only. We can start another thread for other form factors if we have enough of them.
    Jan Bennett
  10. #40
    Oct 2007
    RedGTiVR6
    On page one the Kino 9452 isn't a 755 socket, I'm pretty sure it's an M looking at the photo.
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. mac mini core solo enough for bootcamp?
    By replicant in forum MacCar
    Last Post: 06-27-2006, 12:49 AM
  3. Replies: 7
    Last Post: 07-19-2005, 06:24 PM
  4. MINI atx or Itx
    By JDTUNER in forum General Hardware Discussion
    Last Post: 06-01-2005, 11:31 PM
  5. Where to Purchase Jetway ITX boards?
    By SuperMatty in forum Classified Archive
    Last Post: 05-26-2003, 12:21 AM
