Page 6 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 51 to 60 of 154
Thread: Core Duo / Core 2 Duo Mini-ITX boards
  1. #51
    Newbie smonska's Avatar
    Nov 2007
    L.A. CA
    I have to say this has been one of the most informative posts i have read on the subject, thanks all...
  2. #52
    Newbie rayjr13's Avatar
    Oct 2007
    Dirty South, PA
    Thumbs up Liantec
    I had to email the sales rep for the US at Liantec. I'm ordering two (2) of the 6965 board with expresscard daughterboards next week. We'll see how it turns out. Hope it doesn't take a million yrs to arrive from Taiwan....
    UPDATE: I actually had to hold off til maybe first week of Feb cause of holiday shopping.
  3. #53
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    Quote Originally Posted by smonska View Post
    I use intel dg965ss motherboard
    Intel® Desktop Board DG965SS Features
    Features Benefits
    Form Factor microATX (9.60 inches by 9.60 inches [243.84 millimeters by 243.84 millimeters])
    Processor
    Support for an Intel® Core™2 Duo processor in an LGA775 socket with a 1066 or 800 MHz system bus
    Support for an Intel® Pentium® D processor in an LGA775 socket with an 800 or 533 MHz system bus
    Support for an Intel® Pentium® 4 processor in an LGA775 socket with an 800 or 533 MHz system bus
    Support for an Intel® Celeron® D processor in an LGA775 socket with a 533 MHz system bus
    View all supported processors
    Memory
    Four 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
    Support for DDR2 800, DDR2 667, or DDR2 533 MHz DIMMs
    Support for up to 8 GB of system memory
    Chipset Intel® G965 Express Chipset
    Audio 6-channel (5.1) audio subsystem using the SigmaTel* STAC9227 audio codec
    Video Intel® Graphics Media Accelerator X3000 (Intel® GMA X3000) onboard graphics subsystem
    I/O Control Legacy I/O controller for diskette drive, serial, parallel, and PS/2* ports
    LAN Support Gigabit (10/100/1000 Mbits/sec) LAN subsystem using the Intel® 82566DC Gigabit Ethernet Controller
    Peripheral Interfaces
    Ten USB 2.0 ports
    Two IEEE-1394a interfaces: one back panel connector and one front-panel header
    Four Serial ATA IDE interfaces
    One Parallel ATA IDE interface with UDMA 33, ATA-66/100/133 support
    One diskette drive interface
    One serial port via header
    One parallel port
    Expansion Capabilities
    One PCI Express* x16 bus add-in card
    One PCI Express x1 bus add-in card connector
    Two PCI Conventional* bus connectors
    Microsoft Vista* Premium Ready With a PC built with Intel® Core™2 Duo or Intel® Core™2 Quad processors, and the Intel® Desktop Board, you can experience a more responsive and manageable environment of Microsoft Windows Vista* including a new visual sophistication of the Windows Aero* interface.
    Related Products
    Processors
    Chipsets Intel® G965 Express Chipset
  4. #54
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by customaudioman View Post
    Features Benefits
    Processor
    Memory
    Ten USB 2.0 ports
    One parallel port
    Related Products
    Processors
    That does look like a nice MB to use but this thread is for mini-ITX MBs not Micro-ATX.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  5. #55
    Jan 2008
    Agreed. I was just researching for a decent Socket P mATX mobile-on-desktop board, and found that they're mostly Mini-ITX these days, and this thread has a wealth of info!
    I'm glad google brought me back here, as it's been a few years since I visited the site often (around 2004). It was definitely a pleasant surprise to see C2D on Mini-ITX size boards, especially since I was used to seeing VIA C3 stuff on that size back then.
  6. #56
    Dec 2002
    Hi rayjr13, I'm also trying to get hold of Liantec boards, so please could you let me know if you get a response from their rep, and prices etc.? I'm actually after their Geode board, but can't find their products in the retail/distribution chain anywhere...
    cheers
  7. #57
    Jan 2008
    Better picture of the MSI Fuzzy 945GM2:
  8. #58
    Constant Bitrate vull's Avatar
    Oct 2007
    i've found a site which tested couple of boards:
    http://www.epiacenter.de/modules.php...id=233&page=10
    why the hell is C7 processor so good compared to core duo on J9F2-extreme board? (when you look at the HD playback)
    or am i missing something as i can't understand German?
    i thought i'd go for J9F2, but after seeing the charts, i started to look for a better board :|
  9. #59
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by vull View Post
    When I read this I thought "crap"! I just bought a J9F2 and a nifty c2d chip to go with it too.
    Then I thought, "self, this cant be right" so I looked at it again.
    The J9F2, is the #1 board on almost everything there. It is CPU utilization. so maxed out at 100, means the CPU is 100% taxed compared to the J9F2's 30% at 1080i.
    And I am pretty sure this entire paragraph is giving the "Jetway Main Board" high praise for not even flinching with a T7200 no matter what they did to it:
    Auch hier wird das J9F2 mit den gestellten Anforderungen ohne Probleme fertig. Auch HDTV kann die Platine mit dem T7200 erwartungsgemäß nicht ins Schwitzen bringen. Beim VLC-Test weicht die CPU-Auslastung wieder einmal kaum von den vergleichbaren Boards ab. Es sei noch erwähnt, dass das Jetway J9F2 alle Formate ohne Probleme mit allen Playern wiedergeben konnte. Alles in allem liefert das Jetway Mainboard eine runde Performance bei der Videowiedergabe ab und die CPU-Last lag selbst bei 1080i mit keinem Player über 41%.
    1.9in x 2.9in -- 47mm x 73mm
  10. #60
    Oct 2007
    Quote Originally Posted by 2k1Toaster View Post
    cool, thanks
    that explains everything indeed
    i thought i need to go through shtloads of motherboards now to find the best one
    they all have nice names as well - something like FADJ8734aSDASD/&/ASD
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. mac mini core solo enough for bootcamp?
    By replicant in forum MacCar
    Last Post: 06-27-2006, 12:49 AM
  3. Replies: 7
    Last Post: 07-19-2005, 06:24 PM
  4. MINI atx or Itx
    By JDTUNER in forum General Hardware Discussion
    Last Post: 06-01-2005, 11:31 PM
  5. Where to Purchase Jetway ITX boards?
    By SuperMatty in forum Classified Archive
    Last Post: 05-26-2003, 12:21 AM
