Results 21 to 30 of 32
Thread: Stereo Sub Vibration Causing Pc To Reboot!
  1. #21
    Newbie knightmare007's Avatar
    Mar 2007
    Cicero, NY
    Quote Originally Posted by greatwhite View Post
    You seem determined to do what you want to do, so do it.
    I wil tell you this though:
    There are a lot more powerful carpc audio setups here (mine is one) that do not have your issues and a capacitor is not required. It sounds as if you have a power supply or wiring issue somewhere.
    Have you done the "big three" yet? This will fix most power problems in a "modest" system such as yours. Alot of wilder systems also.
    2k is right and you've been listening to the wrong people................
    Nothing personal.
    Good luck
    im only determined to fix this, hence me out there today in the 96 degree weather disconnecting my cap to test the theory. it didnt pan out and i posted my finding. seems perfectly reasonable/logical to me.
    as for the big three, im doing that next, i just read about it and never really heard of it before today, while i dont think it will fix it because my life is never that simple, i will give it ago, and once again post my finding either way.
    Thanks, the ubernoob
  2. #22
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    The "big three" has fixed more light dimming and power issues than you might think.
    It's quick easy cheap and simple.
    Actually, it should be the first step everyone does...............
    Even on a stock vehicle.
    Good luck.
    Leonardo Da Vinci
  3. #23
    Mar 2007
    Cicero, NY
    Good luck.
    WOW WOW WOW WOW!!!!!!!!!!!!!!! thats all i can say.
    I cant belive I have never heard of this upgrade before, its so simple and makes so much sense when you think about it. This made all the difference in the world. It got rid of the rebooting and light dimming completely. I ran 4 guage on all three wires on top of the factory wiring and it solved my problems like magic.
    That is with the cap removed. so i guess caps are useless wastes of money, cant belive so many people are wrong, but then again, look at religion.
    When i changed form 8 guage to 4 guage back in the day it made a huge difference, and being that the altanator is running on like 8 or 10 guage, and the amp is trying to pull tons of power off the 4 guage it just creates a big bottle neck, run the 4 guage all the way to the alt and then your set.
    I actually went to installations unlimited today to buy the wire and asked the guy if hes herd of the big three, he hadn't so i explained what it was, he said they only do that when somone upgrades they re altanator.....thats pretty ******* stupid.
    They are like the big car audio install guys around here, and they charge alot, and they don't do that service religiously? thats amazing to me.
    Thanks for the advice guys, it really made a difference for me. i suggest anyone else reading this to do the same if you havn't already, its no joke.
    THIS SHOULD REALLY BE MORE WELL KNOWN!!!
  4. #24
    Mar 2007
    Cicero, NY
    Quote Originally Posted by 2k1Toaster View Post
    whoa whoa whoa... You had the lights dimming? Your battery is no good.
    And no, a capacitor is useless. And yes, a capacitor is more trouble than it is worth. Just bypass and see if it works. And if your lights are dimming then you have some issues you need to correct. A cap will "bandaid" it, but as you are finding out not well.
    Also a cap has a maximum current it can pass through. So if you are using awg to the cap and then to your components from that, you may be underpowering them because the cap is the chokehold. Once the capacitor is called on to give up its storage of energy, the current available drops exponentially and will take some time to "recharge" by Kirchoff's Laws. So if your battery cant handle it to begin with (which is why the cap is used), then now it has to both recharge the cap and power everything
    why after bashing the cap did you make no mention of the big three as a possible fix???
    seems if your gonna say something is horirbly wrong, you might mention an alternative solution.
  5. #25
    Variable Bitrate rijndael's Avatar
    Apr 2007
    Florida
    one thing you are probably going to want to do is after this is upgrade your alternator. dont just wait until it kills itself along with your battery, have it re-spun or replaced with a higher amp output version. your stock alt will probably not last very long with a system in it...
    Trouble deciding on car speakers? Clicky Clicky
    My Myspace page (view my pics for carputer worklog...needs updated)
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
  6. #26
    May 2007
    glad to help.
    As I've always said, the components are only part of the equation. The install is what makes or breaks it.
    Cheers
    BJ
    Leonardo Da Vinci
  7. #27
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by knightmare007 View Post
    Because by the time I read your thread again, it had already been mentioned. Seemed sort of useless to say it again.
    But I can if you want... "Why dont you try the Big 3?". I think this is even mentioned in a FAQ somewhere.
    Good thing you got it working, and now you can "preach" () the uselessness of caps as well.
    1.9in x 2.9in -- 47mm x 73mm
  8. #28
    Mar 2007
    Cicero, NY
    Quote Originally Posted by rijndael View Post
    its lasted 2 years so far, and if it goes, then ill get the higher output one, if it takes my battery too.,....so be it.
  9. #29
    May 2007
    A higher output amp is not really required on most stock to mild systems. It is nice to have a higher amp alt if you do a fair bit of traffic driving though. Not because it has a higher peak output, but because it produces more power at lower rpms.
    And if the alt dies after "the big 3", it will be because it's on the way out anyways, not because of the improvement in the wiring.
    But a bad alt will take out a battery. However, it doesn't "kill" the battery, it lets it die. The battery stays in a state of discharge as the alt can't bring it back to full charge, the plates sulfate, and the battery dies a slow and painful death.
    Batteries need to be kept in a state of full, or near full, charge to get the full service life out of them.
    Cheers
    Leonardo Da Vinci
  10. #30
    Apr 2007
    Florida
    so what you're saying is that "The Big 3" upgrade will negate a need for a new alt or re-spun alt with a powerful sound system? did i catch that right?
    Subwoofer: removed
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 05:20 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  3. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  4. FS: HP iPAQ Pocket PC h1910 w/ Stereo Earpiece
    By astral in forum Classified Archive
    Last Post: 08-03-2003, 02:18 PM
  5. How to hook up PC to stereo...
    By Telek in forum General Hardware Discussion
    Last Post: 10-28-2002, 10:23 PM
