Results 1 to 4 of 4
Thread: Cutting off PCI slots - anyone tried it?
    May 2007
    Hi, I need to wedge a new thicker VGA card in My custom PC case but in order to get it to fit I will need to cut off or desolder the PCI slots. has anyone tried this? any tips / pitfalls I should be aware of? I was planning on filling the dead slot with Hot Glue in order to insulate it.
    Comments please!
    Jan 2005
    well I have never removed a pci slot but i would think that a good desoldering turn would be your friend as to the pitfalls i have no idea what to tell you.
    Yonu
    May 2007
    lol, that would be the neatest but theres an awful lot of desoldering to do. I may be able to find an old board at work to play with first. as the pitfalls I was wondering how Windows may react, I'm guessing that it won't as the circuitery would still be present just the actual slot would be missing. If I do it I will post the results here!
    Mar 2006
    Colorado, but Canadian!
    as long as you do a good job and dont overheat the traces and blow the multi-layer PCB or heat up a nearby component it should have no adverse effects.
    Just get a desoldering braid, lay it over the bottom pinsand run your iron over it.Then it should be mostly free and do it by feel then.
    1.9in x 2.9in -- 47mm x 73mm
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Need Mini PCI slots?
    By Giuliano in forum General Hardware Discussion
    Last Post: 12-06-2006, 02:52 PM
  3. More pci slots?
    By sporty_drew in forum General Hardware Discussion
    Last Post: 05-16-2006, 08:42 PM
  4. Hot glue in PCI slots
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-16-2001, 10:59 AM
  5. adding pci slots?
    By etrik in forum General Hardware Discussion
    Last Post: 04-04-2001, 08:28 PM
