Results 1 to 4 of 4
Thread: Do I need a powered USB hub? Or will a regular one work?
    Aug 2007
    Just wondering if I need a 5 volt usb hub....or if i can get away with a regular one.
    Uses: A wireless keyboard, from time to time.
    Possibly but very sparingly a mouse.
    Monitor?
    Camera?
    Microphone?
    ipod?
    GPS?
    Obviously not everythig will be used at the same time.
    Just not sure what to get.
    May 2004
    Denver
    yeah, you are more than likely going to need a powered hub... if all those things are plugged in at the same time you will get drop outs where one of them stops working, or all of them stop...
    if you use the various USB ports on your motherboard, you might be able to get away with NOT having a 5V supply... you can "steal" the 5V off of your power supply...
    EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
    Aug 2007
    Okay..thanks for that info. Next question: How do you 'power' the 5V usb? Is it connected to the P2140? Or is it a separate entity going straight to the battery?
    May 2004
    Denver
    red/black wires (that lead to hard drives) provide a stable 5V, so you tap into those... or you can pick up a small 5V regulator... they have one for like $30 in the mp3car store
  1. USB Audigy 2 NX, D-Link USB Hub, and 15 W POL
    By Caelric in forum Power Supplies
    Last Post: 01-17-2006, 01:02 PM
  2. Best Bet USB Hubs Powered and Non Powered
    By lostreception in forum General Hardware Discussion
    Last Post: 06-19-2005, 05:51 PM
  3. USB Hub does not show HD after cold boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 04-05-2005, 02:46 PM
  4. FS: 4-port powered USB 2.0 Hub $10 Shipped
    By Altimat in forum Classified Archive
    Last Post: 02-14-2004, 04:30 PM
  5. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 04:21 PM
