Results 1 to 4 of 4
Thread: EPIA M-10000 - LPT voltage output = 3.5V !?
    Jul 2007
    Hello everybody,
    I found out a strange thing in my LPT output on EPIA M-10000 when I put '1' there. The '1' voltage is about 3.5V but it should be 5V. Did anybody meet this problem - or it's just a normal for EPIA M-10000?
    I use special device that connect the relays .... but it works with 5V ... :-(
    Regards, Alexy
    Aug 2008
    I've the same problem, but on ASUS A8NE-FM\S.
    Jan 2007
    Szeged, Hungary
    OK, what happenned under loading condition (I mean via approx. 1K to the ground)?
    Are you sure, that your port is in output mode? (In BIOS you can select the LPT mode, put it into normal, - unidirectional - mode)
    Does the problem still exist?
    Then find the driver IC (directly from the lpt port back). Measure the input Vcc. Measure output voltage.
    If there is no driver IC, you can use a USB->LPT converter.
    Alopecia perniciosa
    Jul 2007
    that's not actuall any longer for me because I switched to K8055 Card
  1. output software program for the game or LPT port???
    By 2k1civic in forum Software & Software Development
    Last Post: 11-21-2005, 03:04 PM
  2. Anyone try a Forward Converter?
    By presslab in forum Power Supplies
    Last Post: 05-17-2005, 09:09 AM
  3. No Video from EPIA MII 10000
    By skippy76 in forum General Hardware Discussion
    Last Post: 04-19-2004, 09:04 PM
  4. 6 channel output from EPIA MII
    By ajaswa in forum Newbie
    Last Post: 03-16-2004, 05:29 AM
  5. Power Voltage DC Output etc
    By leesilk in forum Power Supplies
    Last Post: 05-23-2003, 09:27 AM
