Results 1 to 10 of 14
Thread: Alarm/Remote Start - $549 for hardware an overkill?
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    I only found one real thread with recommendations, but most were just referring to DEI (which is about 80% of the market right?).
    The thread was also encouraging the OP to do it himself.
    Goal:
    1/2 mile remote start, with indication that it started. So I don't have to wonder if it started or not. Basic alarm function, the car won't get stolen, and in most cases I'm not going to run out of class, and across campus to check to see if someone is breaking into my car, or if no one is around and some student accidentally brushed into it with their backpack.
    Suggested Hardware:
    Python 990
    Has 1 mile range with indication, and great (more than enough) alarm features. It only comes with one remote which seems to be a risk to me. I like having a spare key and access to the car, just in case I lose my keys somehow. So to replace that, will actually be roughly another $100, so total should be $649.
    The installer will charge $100, so upwards of $749 (with two remotes), otherwise $649 installed.
    Is this an overkill for what I'm wanting? Seems drastically high, but then again, I dont' know much about these things. I read where Red recommended avoiding cheap systems, or you will pay for it later.
    Appreciate the advice!
    Mar 2006
    Colorado, but Canadian!
    Well I have the Audiovox unit and no regrets, so cheap is not always bad.
    However what I have wont do what you want. I know how to get the infinate range for alarms and starting, but I am not sure about the confirmation. I suppose you will need a 2-way paging system...
    Also 1mile... Yeah right. Maybe in a flat field with line of sight, but a dinky keychain wont get a mile all the time. Maybe with a new battery a cold day and no hills, but otherwise, I dont think so. Usually if I can see my car, I can get it to start. So from 1 building that I can "see" my car (maybe other cars in the way, but I can see where it is parked no buildings in the way), I just push the remote start button 3 times and pretty much everytime it is started.
    If you are interested in the big range (not sure about the confirmation though), Audiovox has the CarLink products that actually uses a telephone and satellite. So anywhere in North America that your car can see the sky (or you at least get a cell/gps signal) and you have a phone (cell probably), you can dial into your car, enter your pin number and select the code through an automated number.
    I thought I read about a 2way pager somwhere, but I think I was mistaken.
    1.9in x 2.9in -- 47mm x 73mm
    May 2007
    Springfield, Va
    I actually only need roughly 1/4 mile at any given time, which I imagine the 1 mile performing as (like you said, laughable that they advertise 1 mile).
    The two places I park the most are both in parking garages, so the car won't have line of site. Even when I go out to eat or a movie, half the time I'm in a garage (semi city life).
    I did read extensively on the CarLink stuff, and it seemed nice, but I didn't think of the sky view (same as my temporary gps device which doesn't work in garages).
    Mar 2006
    yeah a parking garage will disable the CarLink.
    Its good that you dont expect a mile range! Anywho, I still think $750 is too expensive for something this simple.
    Do you get a cell signal in the places you park? You may want to look into using the cell phone as the receiver. If you have a phone add it to your plan and then you can call your car and it can do whatever and send you back a message on success failure. More complicated though, but doable and I think even on the boards.
    I will see if I can dig up some better prices for systems for you.
    Mar 2006
    $220 shipping included: http://cgi.ebay.com/VIPER-5500-REMOT...QQcmdZViewItem
    Viper alarm:
    Viper 5500 SST 2 Way Remote Start
    with Keyless Entry System
    *User-friendly 2-Way SST Remote with the
    Ultimate 2-Way Remote Start
    system and up to one mile range!
    *SST Remote Spread Spectrum Technology
    *FCC-Legal Remotes - No Risk of $11,000
    Forfeiture penalties per violations!
    *Responder Technology: Unique LCD
    Interface for 2-Way communication of
    command confirmations!
    *Confirms all commands with easy-to
    understand icons, plus text!
    *Alerts users to Remote starting
    by Beeping or Vibrating!
    *Responder alerts you when
    too far away to hear it.
    *Only available 2-Way SST Remote
    with 66-bit digital Code-Hopping!
    *Includes a Belt Clip
    *Turbo timer and optional rear
    defroster activation output.
    *Dedicated 1 button start
    *Parking light flash
    *+/- Doorlock Polarity Outputs
    *One 4-button LCD SST Remote
    *5 channels
    *Flashing Blue LED light
    *Valet switch
    *Domelight Supervision output ready.
    *Failsafe Starter kill Built in, along with
    Remote Start Anti-grind (active/passive).
    *Horn Honk output
    *Remote Panic/Car Finder
    *Viper quality, with Limited Lifetime Warranty!
    *Super High Frequency Receiver (SHF)
    *XCRS-4 relay H/D capacity satellite relay.
    *Automatic configuration of remote buttons.
    *All models are Clone-Safe Code Hopping
    *Diesel mode with dedicated glow plug input.
    *Complete engine monitoring: Voltage or Tach
    *Programmable run times: 12, 24 or 60 Min.
    (0-60 minutes with the Bitwriter tool).
    *Dedicated factory security control wires.
    *Viper GPS Tracking System: ESP serial port
    Viper 5500 SST now includes the XHF2
    Super 2-Way Dipole Mini Antenna with
    about a 1 mile range!
    900MHz Spread Spectrum transmitter / receiver technology that provides roughly 10 times the power of traditional systems, enabling operating range of up to 1 mile. SST also allows for consistent operation in even the toughest of conditions.
    May 2007
    Springfield, Va
    Very slick, much better price.
    Really appreciate it!
    Mar 2006
    Well that was a quick google and ebay lookup. I think Viper is regarded as a good brand. I personally have never used any of there products though.
    You might be able to find a better and cheaper one with more searching and patience with ebay. (auciton instead of BIN).
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i bought mine off of ebay for around 100 bucks. Installed it myself and it works perfectly.. even has bells and whistles like proximity lock/unlock, window roll up and a/c and radio turn on.
    Live mp3Car Facebook Chat
    May 2007
    Springfield, Va
    Which one are you using?
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Phatsacks View Post
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=012
    its actually the second alarm i bought from him with no issues.
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. RR hangs on start up
    By fixerofallthing in forum Road Runner
    Last Post: 04-16-2006, 11:05 PM
  3. Failed Hiding of Start Bar, Minimize Errors
    By DaRacerz in forum RR Bug Tracker
    Last Post: 11-04-2005, 05:36 PM
  4. Clifford Car Alarm/Remote Start
    By linuxguy in forum Hardware Development
    Last Post: 12-22-2004, 09:35 PM
