Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: Sirius problem...
  1. #11
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    I don't believe the SB Audigy SE will allow this.
    So do the sound processors replace the amp I already have, or is this just a supplemental piece of equipment?
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    They are essentially pre-amps.
    There are a few options out there.
    Processor Options
    Might help you decide.
    Jan Bennett
  3. #13
    Jul 2003
    Yeah, I saw that last night on my search, but as a newb on car audio, didn't fully understand what I was looking at.
    Is the the Alpine 701 you are referring to?: Click Me
    Current build! Here
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    If you go with the Alpine you will need the RUX and the PXA.
    You're also looking at a few hundred bucks ($400+)...so you may or may not be in the right price bracket.
    Jan Bennett
  5. #15
    Jul 2003
    Quote Originally Posted by RedGTiVR6 View Post
    You will either have to use somethine like the Alpine 701 or some other kind of EQ.
    Some cards cannot do digital and analog outputs at the same time, some can. You might check and see if there's a setting to allow both. I know the onboard sound on my mb899 has this setting.
    Also, is there a FAQ on which soundcards can do both at the same time?
    Current build! Here
  6. #16
    Aug 2006
    You could also use the alpine pxa-h510. Quite a bit cheaper than the 701 and it has its own wired controller.
  7. #17
    _
    Mar 2004
    Little Elm, Texas
    No FAQ because there's just not enough people asking about it.
    Feel free to write up a thread when you find a few.
    Jan Bennett
  8. #18
    Jul 2003
    Will do.
    Current build! Here
  9. #19
    Jul 2003
    Would this work?
    Eclipse DCU105
    Current build! Here
  10. #20
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Assuming you're still running Roadrunner, the winamp linein plugin will allow you to play the SPDIF input. You have to change the sampling rate from 44.1 khz to 48 khz but other than that it works like a charm.
  1. Sirius shows mp3 list-xm logo , not channels
    By sentiensx in forum RR Bug Tracker
    Last Post: 06-05-2008, 01:51 AM
  2. Is this all I need for Sirius in car?
    By Kurack in forum Newbie
    Last Post: 08-21-2007, 08:45 PM
  3. RR 08-02-05... SIRIUS Support ...
    By guino in forum Road Runner
    Last Post: 03-09-2006, 02:44 PM
  4. Sirius and MJS
    By randomjohn in forum Road Runner
    Last Post: 03-08-2006, 11:42 AM
  5. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 05:55 PM
