Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Sirius problem...
  1. #21
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    So are you saying I should be able to get the line-in from the SPDIF, and still be able to play back in regular Analog mode?
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  2. #22
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Yes, with that specific plug-in for winamp. The only other way is to use Centrafuse, it has SPDIF support for Sirius.
  3. #23
    Jul 2003
    Where is said plug-in, now that you mention it? Also are you saying this would work with my Sound Blaster Audigy Soundcard, with the Digital I/O Module?
    Current build! Here
  4. #24
    Jun 2007
    http://www.winamp.com/plugins/details/84040
    And you configure it through RR with RRConfig.
  5. #25
    Jul 2003
    Thx. I'll give it a try.
    Current build! Here
  6. #26
    Jul 2003
    Quote Originally Posted by Machinehead View Post
    Assuming you're still running Roadrunner, the winamp linein plugin will allow you to play the SPDIF input. You have to change the sampling rate from 44.1 khz to 48 khz but other than that it works like a charm.
    Ok, I tried this yesterday, and I heard nothing from Sirius. Was able to see the channels loading, but no audio. I enabled the the plugin for Sirius in RR. When you say change the sampling rate, where am I needing to change it at?
    Current build! Here
  7. #27
    Jul 2003
    Anyone?
    Current build! Here
  8. #28
    Jun 2007
    Quote Originally Posted by LinuxRacr View Post
    If you aren't getting any audio something isn't set right.
    Or connected right.
  9. #29
    Jul 2003
    Where do you change the sampling rate at? Is that something you modify in RRconfig?
    Current build! Here
  10. #30
    Jul 2003
    I am just trying to make sure I am changing it in the right place.
    Current build! Here
  1. Sirius shows mp3 list-xm logo , not channels
    By sentiensx in forum RR Bug Tracker
    Last Post: 06-05-2008, 01:51 AM
  2. Is this all I need for Sirius in car?
    By Kurack in forum Newbie
    Last Post: 08-21-2007, 08:45 PM
  3. RR 08-02-05... SIRIUS Support ...
    By guino in forum Road Runner
    Last Post: 03-09-2006, 02:44 PM
  4. Sirius and MJS
    By randomjohn in forum Road Runner
    Last Post: 03-08-2006, 11:42 AM
  5. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 05:55 PM
