Results 1 to 3 of 3
Thread: Via NX15000EG Nano Audio headaches... Help...
    LAME :) lopan's Avatar
    Dec 2003
    Clarksville TN
    The via manual lists the following connectors. (they make you make your own cables with this board).
    1 SPDIF_OUT
    2 +5V
    3 GND
    5 LINEOUT_R
    6 LINEOUT_L
    7 LINEIN_R
    8 LINEIN_L
    9 MICIN1_R
    10 MICIN1_L
    12 NC
    13 AGND
    14 AGND
    It seems that no matter which grounds I connect my cables to, I can either get Linein to work, or lineout. Not both at the same time, it's a ground issue, the problem is that the manal is all the information via provides anywhere I've seen. are you supposed to tie all grounds together???
    Anyhelp would be greatly appreciated.
    Mar 2006
    Colorado, but Canadian!
    Well that is for front panel audio.
    Why dont you just use the audio out on the back ports? You can only use 1 at a time.
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2003
    Clarksville TN
    not that easy.... nx15000eg and nx12000eg boards have no rear connections... everything is board headers... vga, audio, usb.... VIA kindly decided to not provide anything but usb and vid cables.
  1. iPod nano / Honda Civic
    By benvallack in forum Show off your project
    Last Post: 09-20-2005, 05:35 PM
  2. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  3. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  4. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 02:44 AM
