Results 1 to 2 of 2
Thread: Mod a voompc (v1) to act as heat sink?
    Nov 2005
    Hey,
    I have a VIA M10K MB M@-atx and a voompc v1.
    Is it possible to make the Voompc case act as a heatsink for CPU, north and south bridges of the M10K?
    I dont want to replace the CPU fan, maybe side mount it?
    My carpc is going to be in a enclosed section of my boot and just worried about temps. Plus it seems a waste that the voompc is 5mm alu but cant be used as a heatsink.
    Cheers
    TB
    Nov 2005
    no idea's?
    I was thinking maybe change the way the MB plate slides into the case and instead screw it in from the base then add some sort of aluminium "block" so that the north/south and CPU heatsinks push against that block that is then secured to the case. The cpu Fan is side mounted and blows across the cpu heat sink and twards the right of the mb (further cooling hte north and south bridge)?
    comments?
  1. Wanted: M1000 Low Profile Heat Sink
    By JPMG in forum Classified Archive
    Last Post: 03-21-2006, 10:47 AM
  2. Low profile heat sink with fan
    By gt__1 in forum General Hardware Discussion
    Last Post: 09-23-2005, 03:52 PM
  3. Chopping up a heat sink
    By Speg in forum LCD/Display
    Last Post: 07-13-2005, 08:49 AM
  4. Low profile AMD XP 2500 heat sink (no fan)
    By Arathranar in forum General Hardware Discussion
    Last Post: 01-08-2005, 04:15 PM
  5. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 09:46 AM
