Results 1 to 3 of 3
Thread: Should I upgrade my battery?
    May 2006
    Calgary, Alberta
    I've heard yes and I've heard no, probably both from this site. But I was wondering if anyone could run the math on it for me.
    I'm running a carputer off my stock battery and alternator and stock wiring between them as well. I now have an air ride suspension that I want to hook up to the carputer with the Fusion Brain and I'm wondering if the strain of that on the battery/alternator will be too much. I know you need some information from the kit to run the numbers but what information? I can get you whatever you need. I've also got a 120 watt 4 channel speaker amp and a 325 watt bridged subwoofer amp. And as my signature states, a M1-ATX with 4 USB ports used....Wi-Fi receiver, bluetooth wireless keypad, touchscreen and GPS receiver. I'm hoping I haven't left out anything people are going to tell me to search for.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    figure out the total used wattage.., divide by 12 (volts), that will give you the total amperage..
    make sure your alternator can handle the amperage used by ur system (well, make sure that if your system uses say 20 amps, that ur alternator puts out more than that, so that ur battery gets charged) and u should be fine
    May 2006
    Calgary, Alberta
    Ya the alternator is 70 amps and the compressor for the air ride is 18 amps. I'm getting there.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Connecting AC Power Source to Car Battery
    By SolusCado in forum Power Supplies
    Last Post: 08-06-2008, 02:23 AM
  2. Replies: 2
    Last Post: 05-16-2007, 07:32 PM
  3. Two battery Setup for carputer
    By ThunderStick in forum Power Supplies
    Last Post: 01-28-2007, 11:10 AM
  4. What kind of cap/amp?
    By asong31 in forum Car Audio
    Last Post: 12-26-2006, 02:30 PM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
