Results 1 to 10 of 11
Thread: Compact Flash card
    Aug 2006
    Compact Flash card
    So, I've finally decided to RMA my Transcend IDE Flash module and just go with the CF to IDE converter with a standard CF card.
    So, I was wondering, what are some good flash cards that work for you all? I know that it needs to support a certain format/mode, but I can't remember off the top of my head...
    Basically, I want/need this program to run my OS (nLite-d version of XP) and maybe a few applications.
    Thanks for any suggestions!
    Low Bitrate slinkytoy's Avatar
    Mar 2007
    Colorado
    I had the same problem i also decided to move to a CF. Here is what i have.
    http://ec.transcendusa.com/product/I...ID=TS8GCF45I-D
    I got this one for 60 bucks on ebay great deal. If you look around you can find pretty deals on them. Transcend seems to make a pretty good product. These CF support diffrent modes also read up on the card on the web site real good info. Hope that hepls you out.
    Here is the adapter that i bought for the card also.
    http://www.addonics.com/products/fla.../adebidecf.asp
    These guys make a good product also.
    slinky
    FLAC SFiorito's Avatar
    May 2004
    Try to get one that supports UDMA and don't underestimate on the size requirements.
    Aug 2006
    Thanks for the suggestion, slinky! I'm gonna look around and see if I can find a less-pricey version on ebay or something, or a slightly lower amount of memory. $260 for a CF card is a bit high...
    Did you really need 8GB? Or would something like 4 or 2 suffice?
    Also, does it need to be "fixed" or does it matter? I was reading something about that and wasn't sure...
    Aug 2006
    Anyone have an opinion on this?
    Mar 2007
    Colorado
    Looks pretty good. UDMA is a plus. Nice speeds on it. I couldn't find anything that lets you know what the max number or writes that the card can do. Most the time you will see like 10,000 writes or 1,000,000 writes. The higher the better. Windows is a write happy OS Read the link addonics site that shows you how to disable the write to disk function in windows. 4 gig is fine if you use xplite and shrink down your windows install then that will leave you room for the rest of your programs. I'm using the 8 gig becasue i got a good deal on it But from what i can see the PNY card looks ok i would do a little more looking around and see if you can get more info on it. Maybe someone here has used that card before. Let me know if you find anything out on it.
    May 2004
    definitely go for an "industrial" card, which is one that can be configured as a fixed drive. This makes things a lot easier, like installing and working ACPI standby/hibernate. Search the OS optimization forums for my threads on EWF and the Hitachi fixed drive filter.
    WRT size: make an inventory of what you plan to run on the main OS drive. If you want GPS navigation then keep in mind that maps are typically very big, so you may need an 8GB drive.
    Jul 2007
    Forgive the noob question, but is anyone running CF cards in a raid 0 set up? It seems like you could use two slower (cheaper) cards in this configuration and get a decent speed.
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    Raid on CF? What are you trying to achieve? Disaster recovery on a carpc?
    Aug 2006
    I'm not sure if that PNY card will support fixed-disk mode or not... Will a flash card not boot if it can't support fixed disk mode? If it will, what are the advantages/disadvantages that make a flash card in fixed-disk mode "easier", as SFiorito put it?
    Thanks for all the help so far--I'm starting to narrow it down.
  1. Compact Flash Extension Cable?
    By maloosheck in forum General MP3Car Discussion
    Last Post: 06-04-2007, 10:41 PM
  2. Replies: 5
    Last Post: 08-12-2005, 10:05 PM
  3. FS: 2.2GB Compact Flash Card
    By Insight in forum Classified Archive
    Last Post: 05-12-2005, 04:26 PM
  4. beating the compact flash horse
    By sdashiki in forum MacCar
    Last Post: 05-05-2005, 09:18 PM
  5. Iomega 340mb microdrive Compact Flash card for $68
    By pdpshaggy in forum Classified Archive
    Last Post: 05-11-2002, 04:31 AM
