Results 1 to 10 of 18
Thread: Hey Guys have a look
    Sep 2002
    Hey guys this is my basic car setup (in theory).lpease tel lme what you guys think.. the relay for the atx switch is called a "one shot" it completes the circuit on for a sec or two.. perfect for the signal to turn on and off the motherboard. Im also looking at a relay that when power is off it switches.
    Prgress: 20%
    collecting: NEW CAR,
    put things on hold,,, gonna wait till the new EPia boards comeout , gonna get jeffs or Maestros DC-DC and jeff shutdown COntroll..
    Have: All in wonder 128, 15gb hd, 128mbs of ram, Prob Win ME, custom under seat case, usb remote
    head unit: pioneer deh-7400, fosgate 700s, and 2 HE2 10's.
    Gona use Cobra and already have a crappy 5.6 lcd.. Gps, Winamp Vis, ANd DIvx.. in heavy construction.
    Sep 2002
    there is supposed to be a box in upper left rpresenting the battery, for some reason it got messed up
    Prgress: 20%
    Jul 2002
    Northern Virginia
    Good start. May I recommend one thing: a DC-DC ATX power supply. I was getting fed up with the noise (electronic and audible) being generated by the power inverter I had and finally bought a ready-made ATX DC-DC power supply (PC Power & Cooling's). It completely changed my setup. The computer doesn't care whether my engine is on, off, or starting. The computer stays on at all times unless I shut it off -- no interruptions. Ignition switch relay is an option, but I don't always like to have the keys in the car while the computer is on.
    Making a drawing is very very useful. Don't do anything to your car without planning it out first. Especially wiring. You can cut down on your installation sessions significantly. I must've taken my seats out about 5 times now to run more cables. And I'm going to have to do it at least once more.
    Anyway, good luck to you and let us all know how it turns out.
    DON'T FORGET A FUSE if you connect anything directly to battery!
    Just curious.. what kind of car are you planning on putting this setup into?
    Thanks,
    Jad
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    I'd make one change. Go from the battery to the inverter. And put a 30 amp inline fuse in-between.
    '98 Explorer Sport
    80% done
    Sep 2002
    oh.. yea i did forget the fuse.. ikinda drew this in a little haste.. im getin very antsy well i was going to put my setup in a Neon put i have to sell it and im moving so it puts things on hold again...Im rally Really hoping in geting a VW jetta, Another option for power (and you guys are gonna laugh) is to get one of those cheap ups at Best BUy (where i work so i get it really cheap) and use the on board shut down option, it would also clean up the signal a little, and you dont have to point out size. .....also i have a 4aug wireing system goint o my R Fosgate amp (700s and He2 10") and speakers, do you guys think i could tap t into that before or after the 1 farod capasitor and get my power to inverter or dc to dc? Thanx again in advance
    Prgress: 20%
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    a UPS is guaranteed to destroy any invertor you plug it into. Not to mention that anything you spend on said invertor and UPS -could- just be put towards a more final solution, like one of ZootJeff's supplies
    Dec 2001
    usa
    CrazyL,
    Could you please explain why a UPS would destroy an inverter? It's not that I doubt you, I'm just curious.
    Thanks,
    Pigseye
    Sep 2002
    i was gonna ask the same thing..also about the Itx power supplys, they sell them with a 12v dc input, wouldnt all you need is a regulator to get them to run right off your battery.. or how about a laptop car adapter withe the right volatage and amps? they would be a lot cheaper than a dc-dc..all opinions count thanx
    Prgress: 20%
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    I think it is because an UPS pulls more power when trying to charge the battery. It might send the invertor into over-load.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Jan 2002
    Oakland, CA
    Exactly. Add the power of the charging circuit (let's say, 150w, but I almost guarantee it's more) plus the power rating of your PSU (more like the power consumption of all your parts, but I digress) And if that number's anywhere NEAR the rating of your invertor, you're guaranteed a nice fireworks show.
    Re: ITX boards - there's a whole thread on finding a suitable 12v transformer for the ITX DC-DC PSU. The big problem you're faced with is supplying 5Amps at 12v from a plug-in transformer.
