You should wire one for spell check.
i am trying to make a panel in the dash to have 4 or 5 switchs, 1 to reset the mobo, 1 to turn on/off the sub amp. what kind of switch would i need and do i just place the switch between the remote on wire and amp thanks
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
fc3s is correct, but maheriano was pretty funny. what kind of switches were you thinking of? adding switches; imho, detracts from a seamless installation. If i were you i'd hide them if you really needed to have the switches. another alternative to switches is fusionbrain, it would be a great gadget to incorperate to control everything you needed/wanted to have a switch besides the mobo reset switch. That would leave you with only one physical switch that you could easily hide.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
fusion brain looks awesome i'll look in to it thanks wow this is really good? but i am a bit confused how would i set up fusion brain with the amp or with the car to control each function
you would connect the amp or whatever you want to use to the fusion brain (not sure if it could control them directly, you may need relays), basically the brain will turn on a relay, which allows power to go to whatever unit
its a good idea, more than good enough for the sounds of what you want to do, and i've never seen anything in the same price range that can do anynthing close to what the brain can
1.9in x 2.9in -- 47mm x 73mm
well here is what i basically need i have 3 amps, i just want to control the remote turn on so i can turn on/off the amp anytime. and then also control the interior neons, my question is how would i use the fusion brain to connect them and also to control other function as describes in the thread
*NEW* USB Input/Output Board -- Fusion Brain
thanks
It is really simple. Just attach a relay to the output pins, and voila a software controlled switched.
so you mean the relay from the site which is 25A
