Results 1 to 5 of 5
Thread: Any Mods Out There Need Help
    Nov 2006
    i'm new to this i need a setup on a via board c7 model 7f 2we1g2e
    with m2atx 160 output power
    hooked up to a liliput monitor which says no signal all the time .. just started to put together .. have the jumpers set as the manual as default .. good or bad...
    every time when i start the ignition ( not the car fully engine running) the mother board has a light .... and the blue led ( voom case ) just blinks .. or doens't even work most of the time
    so anyone out there willing to help plealse ..i have the power connectors setup in my car its just the motherboard and monitor aint working ..no signal.. what should i do .... please notify me assoon as possible ...
    can you show me where i have to connect the cables // i got audio to audio .. usb -- to mother usb 1 .. power conector on the m2atx and mother board .. how to i make it work so i can see the bios screen in the begining .. i have the hardrive setup and connected.
    thanks pictures would help alot
    Elsewhere
    How about the Wiki?
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by DarquePervert View Post
    lol. And breath...
    Elsewhere
    http://www.mp3car.com/vbulletin/advfaq.php
    It's really all that needs to be said.
    You should also consult the manual for your M2ATX PSU.
    How about the Wiki?
    Mar 2006
    Colorado, but Canadian!
    Judging from your other posts, you are someone who doesnt fancy reading or drawing their own conclusions... Also who likes to use CAPS LOCK.
    "Can Anyone Give Me A Good Setup": http://www.mp3car.com/vbulletin/newb...ar-puters.html
    "recomend me a 7inch touchscreen": http://www.mp3car.com/vbulletin/gene...nitor-buy.html
    "what should i get so i can install it to my pc": WIFI/CELLULAR/GPS antenna
    "WHICH BRAND IS THE BEST TO GET FOR A NAVIGATION(GPS)": http://www.mp3car.com/vbulletin/gps/...ople-best.html
    With that being said, I think you need to read the manuals and product info that came with what you blindly bought. As you found out with your rooftop antenna, buying blind is not a good idea. Installing blind is pretty stupid too.
    Quote Originally Posted by WRXUSER123 View Post
    Why do you think the serial number is important? Usually "human readable" model names are given.
    Define: "All the time"
    Does "All the time" =
    a) As you have it installed now
    b) Now and when you hooked it up to a normal computer
    c) Before but not anymore
    d) some of the million other possiblities...
    This is where possessive nouns are useful. Are these jumpers belonging to the monitor, the motherboard, the Ampie case, the M2?
    .. good or bad...
    Would the default of a commercial product be bad? Why would the product have options? If you thought "to make it more customizeable" then you would be correct. Some people want the default, some want a different configuration, and those jumpers allow it. I highly doubt any of them are better than the others for a broad statement such as "good or bad". It all comes down to your personal setup...
    If the mobo has a light then would you assume the mobo has power?
    Where do you have the ampie light hooked up to?
    Where is your ON/OFF mobo jumper going? Do you even have it hooked up?
    "Doesnt even work most of the time" on something like an LED usually means the signal source of the LED is setup incorrectly.
    FAQ = Your Friend
    How did you setup the HD without a working computer? Setting it up and then relocating the HD is usually a very very very bad idea.
    1.9in x 2.9in -- 47mm x 73mm
  1. Unrelated Car Mods
    By kkachurak in forum Off Topic
    Last Post: 05-31-2007, 05:46 PM
  2. Firmware mods Archos/Ipod
    By crabbdaddy in forum Hardware Development
    Last Post: 04-08-2007, 04:52 PM
  3. WinXP SP2 boot times suck(even after mods)!! HELP!
    By ironic in forum Operating System Optimization
    Last Post: 05-03-2006, 07:24 PM
  4. Possibly FS: 2003 Ford Ranger FX4 - LOTS OF MODS!
    By tbird2340 in forum Classified Archive
    Last Post: 07-05-2005, 11:59 AM
  5. Performance Mods
    By fluffy2097 in forum Off Topic
    Last Post: 07-27-2004, 10:57 PM
