Hi it could be a voltage drop from the battery to altenator, loosing just 1 volt could affect your battery voltage alot. Im currently learning this at college at the moment and we were told to do a voltage drop test, you need to create a load in the circuit that's being tested. Then you use the multi meter to measure the voltage drop across the live connection while it is under the load. The voltage always follows the path of least resistance, so if the circuit or connection being tested has too much resistance some of the voltage will flow through the multi meter and create a voltage reading.
If you get a reading of over 0.15-0.2 volts then that could be abit of your problem, there could be a dodgy connection to the battery ternimal (well thats where i would start looking) or somewhere along the circuit. If you do find some corrosion or a dodgy connection it would be a good idea to clean the ternimal or connection and check to see if there is still a voltage drop. If you get a voltage reading of 0.1 or less volts than there should be a good circuit so there shouldnt be to much of a problem.
Well thats my opinion but im only 15 and am not an expert and some of what i said may have been in correct so i would read up a bit about it first. (but im a qualified mechanic, I got my NVQ level 1 a couple of weeks ago)
Many thanks Jack
LinkBack URL
About LinkBacks
). If you continue to have the issue by the time we do a gettogether down here, I can help you troubleshoot it.
