Results 1 to 8 of 8
Thread: Trying to locate an IC
    Jun 2007
    The Mile High City
    This isn't carPC related - I guess it could be if anyone has enough room for a 21" CRT monitor in their car but here goes the question. I'm searching for a Sanyo VP453 IC (video driver IC). Googleing it only comes up with sites that want you to buy qtys of 100 or more. Anyone have a good supplier for simiconductors they can point me to?
    Type slow, I'm old and slow and sometimes forget -- what were we talking about again?
    Mar 2006
    Colorado, but Canadian!
    It is just a video amp right? (http://www.ortodoxism.ro/datasheets/sanyo/VP453.pdf)
    So any video amp should work. Why are you stuck with that component?
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2007
    The Mile High City
    Correct, it is a video amp. To say "any" video amp would work is, well, a broad statement. Yes, any video amp with the same specs and pin outs would work. So far I have found no cross refs to any - NTE, ECG, SK.
    Mar 2006
    Quote Originally Posted by KShoes View Post
    Well you didnt say you needed the same pinouts. I am guessing a chip blew, so you are trying to replace it?
    you could also just get another IC and put it on a different small PCB and wires from pins to pins.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Discontinued
    This mfgr site says that IC has been discontinued. You may find it through their distributors though.
    http://www.semic.sanyo.co.jp/index_e.htm
    ~Jimmy
    Jun 2007
    The Mile High City
    Correct again, and absolutly possible to mount another elsewhere. I would only do that as a last resort - OEM or a direct cross would be my preferred method but thanks for your help.
    Jun 2007
    The Mile High City
    [QUOTE=JimmyFitz;1126880]This mfgr site says that IC has been discontinued. You may find it through their distributors though.
    Thanks, I guess I should have mentioned thats where I started - none of the distributers have been able to help so far - thanks again.
    Low Bitrate marshallh's Avatar
    Apr 2005
    Kansas
    Hunting a chip like that is a waste of time - when google turns up crap distrubutor sites, you're SOL.
    The good news is that as long as you have the datasheet, you can retrofit a modern replacement.
    I'd check the Analog Devices web site for something similar. I think they even do free samples.
    http://www.analog.com
    Progress:
    [■■■■■■■■] 100%
    Mitsubishi 3000GT car computer
    Previous budget Honda carputer
  1. What is Locate?
    By Ravenhawk in forum Road Runner
    Last Post: 05-06-2008, 04:51 PM
  2. Replies: 11
    Last Post: 02-20-2008, 08:17 AM
  3. bluetooth IC
    By modh1984 in forum Wireless Communications
    Last Post: 12-02-2006, 05:46 AM
  4. IC 555 to pulse 1 hour?
    By phita23 in forum Newbie
    Last Post: 02-20-2005, 02:48 AM
  5. Where to locate in F350
    By lukeduke95 in forum Newbie
    Last Post: 09-27-2004, 08:37 PM
