Results 1 to 10 of 19
Thread: VERY cheap car PC possibilities
    Feb 2007
    Maryland
    http://www.fit-pc.com/index.htm
    Check it out, its on the cheap, and could handle basic carPC needs. I think its...$280?
    500 mhz processor with 256 MBs of ram. Not bad
    CarPC status:
    [XXXXXXXXXX] 100% Complete
    [XXXXXXXXXX] 100% Installed
    [XXXXXXXXXX] 100% Software
    CarPC v1.2 is now in effect. Software updates and hardware additions to come.
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Looks awesome with great potential (especially the low power draw), but, 500 mhz would hurt for a lot of people as far as being underpowered goes.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Wow...its hard to believe that it only draws 5 watts. I am running a carpc with xp and centrafuse on a 550mhz p3 machine and it runs just fine with no lag. I am not sure how that 50 mhz will affect performance though.
    Elsewhere
    fit-PC Specifications
    w AMD Geode LX800 CPU @ 500 MHz
    w 256 MB DDR (non expandable)
    w 40 GB Hard disk, 2.5" 44-pin IDE interface
    w Dual 100 Mbps Ethernet
    w SXGA graphics controller, from 640x480 up to 1920x1440
    w Two USB 2.0 high speed ports
    w Speaker and microphone interface
    w RS-232 serial port via RJ11 connector
    w Single 5V supply, 3-5 watt, fanless operation
    w Size: 120 x 116 x 40 mm, 450 gram
    w All aluminum case, black anodized finish. Splash and dust resistant
    w Operating temperature - 0-70oC
    w Gentoo Linux preloaded, kernel 2.6.20.
    Windows XP easily installable using USB CD-ROM drive
    Seach for GEODE on these forums. People have used Geode-based systems in builds before.
    It's low power-draw, but also low-powered. You're not going to be rocking 3D visualizations or ripping DVDs on something like this.
    How about the Wiki?
    Maximum Bitrate DeltaFX's Avatar
    France
    Geode NX != Geode LX
    Now Galileo is real. Muhahahahaha :p
    Constant Bitrate Grimoire's Avatar
    May 2006
    Fayetteville, NC
    Is the CPU upgradable? If I had a spare AMD would I be able to toss it in? Kinda get rid of the OVERLY low CPU size...granted, it would pick up the draw but not by much if I did a small upgrade...
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    thats neat, i had an 800mhz amd, with 512ram and to be honest that just about coped running PC navigator, Road Runner & Phone control.net (Using decent skins ).
    You would have to really tweak windows to get the best out of that, but still its a great idea and size!
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    Feb 2007
    Maryland
    sorry, I'm pretty sure it wont be upgradable. Its not an intel/amd cpu so it will have a weird socket, and unfortunately, its RAM isn't upgradable.
    Install Xp Lite, that works on the barest of systems just fine. (AKA XP without the CRAP)
    I see no prob running the music, frontend, and navi all at the same time. (I'm a legacy hardware buff, i can't throw an old PC out)
    CarPC status:
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    http://gizmodo.com/gadgets/small-lov...iny-310537.php
    http://www.extremetech.com/article2/...2194852,00.asp
    I know that Roadrunner needs a bit of a system to run on...I don't know how well a Geode at 500Mhz does...but a Mini-itx 10000 (1Ghz) system is the equivalent of an 800Mhz cpu...and that is about as slow as you can go for RR.
    But it is tempting.
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Runs from 5 Volts. That would be temping to buy. Easy to get a steady 5 Volts from a car.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  1. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
