Page 5 of 5 FirstFirst 12345
Results 41 to 45 of 45
Thread: Intel D201GLY Little Valley Feedback?
  1. #41
    Low Bitrate Salmizar's Avatar
    Oct 2007
    Ontario, Canada
    Quote Originally Posted by insaneramman View Post
    I tried to get a mic to work today but, it won't? Looked at the audio header and saw two jumpers. According to the set-up sheet they are for the fp (front panel) ? Line in works as well as out to speaker/headunit. Just no mic? Anyone know about this?
    Have you verified that the mix is unmuted from the windows sound manager?
  2. #42
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Wink Now Come on...
    Yes the mic is not muted. Went to the control panel and tried to configure thru the sound and audio devices. Gonna check with another mic just to be sure.
    Ok the problem was the mic ( a soundmax superbeam) hooked up a diff mic and all is great!!!
  3. #43
    Nov 2005
    i am also having problems installing/updating any bios version above 105.
    all the network-card, audio, usb etc. devices are disabled in xp and re-installing devices does not help. it always lists a resource conflict.
    putting bios 105 back everything works fine again. why that? do i need to re-install windows xp? but how if no usb device nor lan is working
  4. #44
    Dec 2004
    Wichita Falls, Texas
    Quote Originally Posted by upspace View Post
    I used to have this exact same problem on 2 of mobos *one was D201GLY the other D201GLY2* I changed out the RAM and it all went away. Earlier in the thread someone stated it does not like High Density modules. I think he/she was correct.
  5. #45
    Dec 2005
    Raleigh, NC
    I have a d201gly and d201gly2. I got the d201gly2 after the first board because I wanted 64 bit support and sata support. The performance is about the same between the two boards. The one issue with the d201gly2 is that there's no fan and the heatsink gets pretty hot (too hot to touch) so I'd recommend using in a case with a fan. I also had Linux, XP, and Vista running at different times without any issues. Right now I'm using the board as a file server and I'm very happy with the performance. I'll probably sell the d201gly on ebay since it's just sitting on my desk now.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Intel D201GLY Little Valley
    By TruckinMP3 in forum MP3Car Products - store.mp3car.com
    Last Post: 04-30-2008, 01:35 PM
  3. Intel D201GLY Little Valley question
    By Snortonnorton in forum General Hardware Discussion
    Last Post: 03-07-2008, 09:34 AM
  4. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 02:56 PM
  5. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 01:16 PM
