Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: Intel D201GLY Little Valley Feedback?
    _
    Mar 2004
    Little Elm, Texas
    For those of you running the Intel D201GLY Little Valley motherboard, what are your thoughts so far?
    What conditions have you run it in? Temperatures? Humidities? Vibrations?
    How long have you been running it?
    Any issues to speak of?
    How reliable is it in your oponion?
    I value any feedback on this board.
    Thanks!
    Jan Bennett
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Not a personal experience, but the guy at a local shop indicated they had several get returned for a no POST condition.
    TruckinMP3
    Read the FAQ!
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    I'm pleased with mine. I'll probably be buying another one for my truck. I've had it for a few months, mounted in my dash. So far I have had one problem and I had to reset the BIOS, right afterwards my monitor went out. I'm using the onboard video, not sure if the two are related or not.
    lot of info here:
    http://www.mp3car.com/vbulletin/gene...l-d201gly.html
    _
    Mar 2004
    Little Elm, Texas
    Lots of info about the board in that thread, but very little in regards to the questions I've asked here specifically.
    I'm looking for reliability issues right now.
    Jan Bennett
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    My systems been goin good now for the couple months i've had it installed. Its been thru a pretty hot trunk so far (on a humid 95 degree day) with no problems. I dont think i've had one odd hardware related crash since its been installed. The only problem i had with it initially was due to high-density ram. It doesnt like it and its hard to detect that the RAM is the culprit at times. Other than that its been the best of the 6 motherboards used in my setups. VERY fast for a 1.3 board. It runs all the same software/skin packages that my amd 2800 ran without a hiccup. Any no post scenarios i've had have been attributed to the bios reset jumper. Once its changed to reset the bios the manual says it will act in a way it doesnt (i think it says bios will be read from floppy but it never read anything). A few mins with no power supplied fixed all post related issues.
    Live mp3Car Facebook Chat
    _
    Mar 2004
    Little Elm, Texas
    Good to know about the high-density ram. Maybe we should note that in the store listing.
    Jan Bennett
    Mar 2007
    Central Florida
    Sorry to ask such a simple question, but how do you know if you have high density RAM? I have a couple of 1GB sticks of DDR2 533 SDRAM sitting around and one of the reasons I wanted this board was to make use of them. Is that considered "High density"?
    Mar 2007
    Quote Originally Posted by TruckinMP3 View Post
    I happen to have one that does not let the keyboard or mouse work. At least when i first installed it.
    I did get the keyboard to work today though, so not sure what's going on.
    Low Bitrate Salmizar's Avatar
    Oct 2007
    Ontario, Canada
    Quote Originally Posted by Profozone View Post
    Hi density RAM's memory modules are on a single side of the stick, where as low density has them on both sides.
    HJC
    HJC is offline
    Apr 2007
    California
    I've got one mounted inside a 8" subwoofer box (no subwoofer of course, just for use as a box). Air circulation is from a system fan and the speaker grill.
    This thing is somewhat tempermental. I use a M2-ATX power supply. I also have a manual switch hooked up in parallel to the on/off jumper for the motherboard. Here is what's a minor, but somwhat dissapointing issue
    -Car is on and running with carPC fully running. I turn off the car all the way off, triggering the M2-ATX to send blip the on/off jumper. This sends the computer to Hibernate mode (as set by the OS). Now, if I turn the car back on while it's going into Hibernate mode, I should be able to use my manual switch to turn the carPC back on once it's fully in Hibernate mode.
    However, half the time it doesn't. When I watch the board, it will sense the "on" signal, the CPU fan rotates once or so and stops. I have to cut power to the M2-ATX or wait the preset 45secs for power to be cut, then restart the comptuer. The little valley will report "CPU overheat error sensed..check settings" or some similar message, then starts up fine. Obviously it's not overheated since I was testing for a few minutes only and all fans were working.
    BIOS is updated too. This exact same scenario played back on my previous old Compaq Presario Celeron 766 results in no restart issues.
    Another issue I've noticed is that my GPS reciever takes noticably longer to get back it's location. Don't understand why.
    All in all, it's pretty fast and cheap. Once you get use to the little quirks, it's a good deal for $70. I would buy again.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Intel D201GLY Little Valley
    By TruckinMP3 in forum MP3Car Products - store.mp3car.com
    Last Post: 04-30-2008, 02:35 PM
  3. Intel D201GLY Little Valley question
    By Snortonnorton in forum General Hardware Discussion
    Last Post: 03-07-2008, 10:34 AM
  4. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  5. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
