Results 11 to 20 of 25
Thread: Commell LV677 BIOS Flash
  1. #11
    Elsewhere
    Quote Originally Posted by galvitron View Post
    I've had bad experiences using USB for booting to DOS and flashing the BIOS. The accepted reliable method is floppy. The chance of bricking your Commell makes it worth the expense. I would highly suggest skimping on a couple cups of starbucks and getting a floppy drive. Definitely worth the 10 bucks.
    I 100% agree.
    Hell, it's worth disassembling your mother's/daughter's/cousin's/uncle's computer to borrow the floppy drive.
    How about the Wiki?
  2. #12
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    ^^^ I keep doing that over the years. Now I have this old floppy drive with no faceplate that is a total eyesore but is like the most reliable PC component I have ever seen. Thing must be 15 years old!
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  3. #13
    Newbie cockie55's Avatar
    Jan 2007
    Australia
    Stompit old post I know but did you ever get your bios rezapped and how noting the Floppy connect on this LV677 MB is foil type so your options pretty limited? If not done to give you inspiration I have this same MB but with a later chip than yours and 1.5 bios and a HQCT-i connected to CD in and she works a treat.
  4. #14
    Aug 2007
    Quote Originally Posted by cockie55 View Post
    I have this same setup as well. I went to Commell's website and they list the latest Bios as 1.51 and for the 945GME chipset. My 677 was listed as the 945 GM chipset. The other bios update they have on there for 1.4.
    Can any of you confirm the exact bios number for the "1.5" ? And, if the 1.5 is actually 1.5 and not 1.51, can someone send me this bios?
    Jay
  5. #15
    Jan 2007
    Australia
    Commell have recently upgraded the LV 677 chipset from Intel 945GM to the 945GME. The last bios update for the Intel 945GM was 1.4. Bios 1.51 is only for the 945GME I believe.
    You can use your audio in for the HQCT however I assume you already have that as a output to a multi channel amplifier?
    IMHO the DC version of the LV677 matched up wuth a Carnetix DC/DC regulator his is bacbone of one of the best Car PC set ups you can build. That said Commell do some weird things like reversing the USB pins.
  6. #16
    Aug 2007
    So what's with the 1.5 bios? Is this for the GM or the GM(E) chipset?
    Jay
    ps...I think I see now about the different BIOS versons. 1.4x for GM, 1.5x for GM(E)
  7. #17
    Aug 2007
    I flashed to the 1.4 bios and that did not fix the CD-in issue.
    Jay
  8. #18
    Oct 2003
    Copenhagen, Denmark
    for anyone who needs the 1.5 for the old style chipset, i have the one commell sent me a while back here : http://www.csaforum.dk/fixcdin.rar
    Not doing carpc anymore
  9. #19
    Aug 2007
    Thank you very much. I couldn't find that anywhere.
    Jay
  10. #20
    Jan 2007
    Australia
    good call dopehead however that is not a bios file but a CDin fix / rar file. Did Commell give you any instructions how to use this fix for the GM chip set and did it work for you??
  1. Replies: 33
    Last Post: 03-28-2008, 03:18 PM
  2. Epia M10000 Flashing Bios Problem, Won't Flash
    By Austin in forum General Hardware Discussion
    Last Post: 02-02-2006, 11:47 PM
  3. EPIA M10000 after bios flash NO VIDEO! help!
    By pir800 in forum General Hardware Discussion
    Last Post: 12-04-2005, 06:59 PM
  4. Replies: 9
    Last Post: 11-21-2005, 07:53 AM
  5. Replies: 1
    Last Post: 09-14-2005, 11:37 PM
