Results 1 to 5 of 5
Thread: This VIA Motherboard
    Oct 2007
    West Covina, CA Name: Steven
    Question This VIA Motherboard
    Does anybody know the speed of it? Rough Ghz Speed if that?
    Its a VIA EPIA something... cant find anything on the motherboard that states exact model name, but research of the South Bridge came up with the following:
    Model Name
    • EPIA-800A
    • EPIA-5000A
    Processor
    • VIA C3/EDEN EBGA Processor
    Chipset
    • VIA PLE133 North Bridge
    • VIA VT8231 South Bridge
    System Memory
    • 2 PC133 DIMM sock
    • Up to 1 GB memory size
    Onboard LAN
    • VIA VT6103 PHY 10/100 Ethernet
    Onboard Audio
    • VIA VT1612A 2 channel AC'97 Codec
    Ports
    • PS/2 for Keyboard and Mouse
    • VGA
    • Printer Port
    • 10/100 Ethernet
    • 4 USB Ports (2 in front/2 in rear)
    • AC 97' Audio
    • Serial Port IO
    System Monitoring & Management
    • CPU voltage monitoring
    • Wake-on-LAN, Keyboard-Power-on, Timer-Power-on
    • System power management
    • AC power failure recovery
    Would this be something I could use for a Carputer or is it not enough power? I need to know before I start deciding any plans. Any help?
    I'm possibly putting this computer in my 1997 Nissan Sentra GXE. The VIA Motherboard comes in a WinTerm Case. I'm still trying to decide if theres a USB DVD/CDRW Burner out that I wont have to use power but just USB instead.
    Elsewhere
    That all depends on what you intend to do with the PC once its in your car.
    Music playback? IT's more than adequate.
    DVD playback? Probably not so much.
    How about the Wiki?
    Oct 2007
    Yes i'll definitely be using it to play music. MP3's and Sirius Satellite Radio. GPS would be nice too and occasional web browsing. DVD playback? Depends if it could handle it. However videos on youtube and streetfire would be cool to be able to watch...
    _
    Mar 2004
    Little Elm, Texas
    If you can take a picture of it someone here can probably identify it.
    Have you looked here on the store at the avaliable pictures to see if you can identify it?
    Jan Bennett
    Constant Bitrate Volsfan's Avatar
    Jan 2006
    Kingsport, TN
    Tennessee Vols Fan
  1. Start problem with new jetway 7F2WE motherboard
    By superkenel in forum General Hardware Discussion
    Last Post: 08-03-2007, 07:06 AM
  2. Still Can't Get New Motherboard To Power Up
    By james33440 in forum General Hardware Discussion
    Last Post: 10-22-2005, 01:02 AM
  3. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 01:00 AM
  4. Which Motherboard to Choose
    Last Post: 06-07-2005, 11:35 PM
  5. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 05:38 PM
