Results 1 to 6 of 6
Thread: Picking up Aussie Radio? Also Good soundcard?
    Jul 2005
    Gday, ignore my newbness, but im still unsure how id go about connecting up an aerial to gain radio access through roadrunner? im in australia, and not sure how its being done?
    Im also wanting to run a decent soundcard to gaiun better audio through amps and speakers, can anyone point me in good direction of well made soundcards that can do the job? and worth the money? PCI i guess would be the go?
    Thanks for the time to read, Ryann,
    Elsewhere
    You need radio tuner hardware that will accept an antenna connection.
    I suggest searching the Roadrunner forums. There are several radio options available for RR users.
    How about the Wiki?
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    I use the dlink DRU-100 for FM radio. it's not available from dlink anymore, but you may be able to find one on ebay if you are lucky. You can use a program called radiator to listen to your radio. Radio functions are integrated into RR
    Jul 2005
    Are there any similiar products to what dlink used to sell?
    Aug 2002
    not sure anymore. basically any FM receiver that uses radiator can be used in RR. You could also have a look at the TV tuner cards with FM as well. You may not use the TV function, but it might be the only way to get FM
    tja
    tja is offline
    Aug 2005
    sydney, australia
    silabs usb tuner is available from farnell here in Australia. seems to be the best option at the moment regarding signal strength whilst moving. also it has a plugin available for RoadRunner. i dont have one yet but will order one soon!
    2005 Nissan Xtrail
    DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
    worklog
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. Usb Radio Driving Me Crazy
    By (6) in forum General Hardware Discussion
    Last Post: 12-09-2004, 04:04 AM
  3. Guidance picking a good HU please?
    By slushieken in forum General MP3Car Discussion
    Last Post: 09-13-2004, 03:28 PM
  4. Line In Mute problem with Radio...
    By ShawJohn in forum MediaCar
    Last Post: 08-20-2004, 06:21 AM
  5. What's a good amp and soundcard to get?
    By mr0range in forum General Hardware Discussion
    Last Post: 10-29-2002, 11:10 PM
