That case looks niiiceee
what did you use to cut that plexi anyhow? seems like you gotta laser cuter of some sort =)
Got the first few pieces of my plexi case done ( i have already managed to crack it AARGH) check out the carputer section of my photo album (in sig)
90% Done
60W DC-DC & shutdown controller
Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
All in a shiny White 2000 V6 Mustang
Click here to visit my NEW PhotoAlbum
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
yeah i used am RFTS laser
EDIT: In case I Confused anyone RFTS = Really Fast Table Saw
90% Done
Plexiglass arent as strong as Lexan. One false move will crack it. Thats why I use Lexan. It's super strong and will not crack even if you beat it with a hammer. The only problem with Lexan is it scratches very easily. When you hit it with a hammer, it'll only leave a mark. If you are a careful crafter or if the plastic must be placed somewhere it can be easily scratched (between the seats) then plexiglass will be a better choice. If you need to put screws in the plastic from the sides then Lexan will be a better choice. This is my prelimiary case. I'll make a better looking case when I have time. Notice the case is screwed together like a speaker box. I did this so I can take the case apart easily and not worry about cracking it.Originally posted by GuRuGoD
That's a pretty good effort for a preliminary case!
Nice job.
Yeah she's going under the seat. I thought about lexan but its also much more expensive. I picked enough plexi to make 2 of these cases for 25 at menards. Not too shabby. I might very well go to laxan later on, but this is just preliminary. Probably wont be what ends up in the car.
90% Done
Your case is coming out very nice! I just made one myself a couple weekends ago, and its not as clean looking as yours is, but it passes enough for me.. I went to a glass shop to get the plexiglass and It cost me 35$ which I thought was a little much and they did a crappy job cutting it too (not going there anymore!) Just out of curiosity, what are you using to connect all the sides together? I used epoxy which I knew was a bad idea from the start beacuse once it hardens it cracks pretty easily, so I ended up using L brackets backwards as corner brackets on each end, which made things a little messier looking.. I didn't know what else to use..
Frank
I havnt attached the sides yet. They are just held down by pressure. I will probably use some plexi glue stuff. They dont have to be very solid. the case is held together by downward presure from the top plate.
90% Done
