Results 1 to 10 of 11
Thread: Audio question
    Nov 2007
    Audio question
    I'm planning on building a completely custom car computer and I was wondering how I could get a VERY HIGH quality audio output. I'm not sure what kind of voltage and power is required for this, and I'd like a cheap way to reach that audio quality. What do you guys suggest?
    Is a simple computer audio output enough to drive 4 speakers and a sub amp? Or do I need to pre-amp the signal? If so, what kind of amps should I use to get a near flat curve?
    Nov 2007
    Memphis, TN
    sound card
    i would suggest that you get a 5.1 channel sound card. I would use PCI if you have one availiable. If not get a usb sound card. Use 1/8 mini to rca jacks to get to a 4 channel amp for your speakers and a mono amp for your subs.
    Nov 2007
    However, I wouldnt be able to control fade and balance right?
    Also, why do you suggest 5.1? How is that better than 2.1?
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by ldiamond View Post
    ...............I was wondering how I could get a VERY HIGH quality audio output............ and I'd like a cheap way to reach that audio quality...................
    These statements don't really go together, depending on what you call "very high quality audio output".......
    Leonardo Da Vinci
    Nov 2007
    or what I call cheap...?
    I can also create the amp myself if its cheaper.
    Nov 2007
    Memphis, TN
    Mainly because you can have better immaging in the speakers from front to back antdthe cost is about the same. The 5.1 audio channel will have 6 1/8 jacks and will allow you to expand later if you want. And also you can use balance and fade like you could with a normal cd player. With some of the new sound cards you have complete control over every speaker in the car in volume control. (FL, FR, RL, RR, SUB)
    (1) Kicker Solo X 18 (2) Kicker CVX 10 (1) Kicker SS6MB (1) JBL P650C (1) MB Quart QC260 (5) Kicker SX1250.1 (1) Kicker SX700.4 (1) Kicker SX600.2 (1) Kicker SXRC (1) Kinetik 2000 (3) Kinetik 2400 (1) Soundstream 40 Fared Cap. (1) Pioneer AVID-Z2
    Nov 2007
    Well you could go digital out, and run a standanlone DAC + analog preamp, but that's not exactly a cheap option (I just sold a dac for $200, and my preamp for $500).
    With a 5.1 soudncard you will have individual controll over your 4 speakers + sub. With a 2 channel you will loose all controll except left/right balance.
    Nov 2007
    I actually thought about having a digital output and making a board with a 24 bit DAC + amp... If I make it myself, I dont think it would be really expensive. The question is... will I get much better audio quality?
    Nov 2007
    Memphis, TN
    I have a similar setup that you are going for. I bought a Kicker SX700.4, which is a 24 bit digital amp, it makes a big difference in your sound. You might want to also consider to upgrade your speakers; you will not hear much of a difference if they are stock.
    Nov 2007
    The Kicker SX700.4 is WAY too expensive!
  1. Audio Question Turtle Beach Roadie
    By 92jdmx in forum Car Audio
    Last Post: 01-05-2007, 07:15 AM
  2. Question about my audio setup
    By djSALIX in forum Newbie
    Last Post: 11-28-2006, 06:37 PM
  3. Laptop Audio Question
    By InVisioned in forum Newbie
    Last Post: 09-25-2006, 01:39 PM
  4. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 03:06 PM
  5. PAC Audio Aux input amp pop question
    By knubile in forum Car Audio
    Last Post: 05-03-2005, 07:28 AM
