Originally Posted by
JimmyFitz
Thanks for pitching in and helping with suggestions guys. I agree that a circuit is a better solution but I don't know if the OP can deal with it. That transistor driver needs for there to be a protection diode clamper across the relay coil or it will probably only turn on and off one time. I suspect that a 3V electromechanical relay will not work any better than the 5V one did without some extra help.
CRAP, your correct. a diode across the coil will keep the transistor from blowing up and possibly your control circuit.
Code:
Diode
5+ ----|<------ GND
Relay Coil
Code block to help make it look better. forum removes empty spaces
