Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 56
Thread: Integrating carPC with BMW E38 wide OEM nav LCD+TV module
  1. #31
    Sep 2008
    Touchscreen on Nav
    Hey, Chris how did the touch panel workout in the end? I did the same to the x3/z4 nav screen. My touch panel was too big though. Where did you source yours?
  2. #32
    Low Bitrate chrislamb's Avatar
    Nov 2007
    Warwick, UK
    Hi Viperian,
    Touchpanel works 100% fine via USB, no probs except finger prints are quite visible, just need to clean it each week.
    I got the touchscreen direct from the manufacturer http://www.magictouch.com.tw
    I had to arrange my own shipping and importation.
    Fit is fine, see the pdf I linked to earlier in this thread.
    I have seen a writeup of a Z4 with this also.
    Hope this helps.
    Chris
    MINI COOPER S PRO
  3. #33
    Sep 2008
    Well anyone know where is radio unit in E38? Because i can't find in the trunk left side where all other things like tv and navi are.
  4. #34
    Sep 2008
    If you have navi thats the only stock position. its silver box with a big square connector. I believe its 17 pins. If you dont have navi then its up front in the dash.
  5. #35
    Sep 2007
    Quote Originally Posted by Evlo View Post
    You have to look carefully, the first thing you notice is the amplifier, with a big aluminum radiator and the radio is hidden beneath it. You can barely see it but it's there.
  6. #36
    Sep 2008
    I found it behind "false wall".
    Now the problem is i cannot slide connector on DSP so i cannout access radio module to see what connectors are on it.
    Also there is some lubricant everywhere.
    Best shot of connector on radio i managed to get - can you tell if it si 10 or 12 pin version?
  7. #37
    Sep 2007
    I am sorry but I can not tell. In fact, what are you finally trying to do? Perhaps I could help you with some WDS schematics if I would know more about your project.
  8. #38
    Sep 2008
    Connect PC/laptop to my E38 - ibus, vido and audio (biggest problem is with audio currently).
    I found out that if i want to use tape wires i will need to have cassete in tape drive so it will make noise probably \:
  9. #39
    Sep 2008
    Now i have another two problems - i don't have +12V in my ibus connector on cdchanger, only ibus and gnd. Where can i taky it on leftside (i don't want to connect directly to battery).
    Also where do i take "remote" for my carPC power source? I have oldstyle radio - do i have to use pin 16 on connector with round pins? I suppose i can use this pin for both - remote and +12V for ibus to com adapter.
  10. #40
    Nov 2007
    Warwick, UK
    MINI COOPER S PRO
