RF Interference Causing Screen Issues?
I have a K90, which since I have installed it into my car has had weird issues were it will work, then unalign itself, then a few minutes later, kind of realign. Also if I close the screen then reopen it (this causes the unit to shut off, including the USB connection). When I open the screen up, this will slightly correct the issue. This K90 is fairly new and I do not think it is the touch panel.... is it posiable that it could be RF interference? Has anyone else ever ran into this issue? I am thinking of going to radio shack and buying a ferrite magnet for one of the ends. The only reason i think it is RF is because I had major engine whine in my speakers, and it turns out it was the USB hubs (which I am replacing, I have one belkin, that gives me no issues, and then I have 2 of these cheapy USB hubs that cant seem to handle anything, and are the cause of engine noise.) I think maybe i will just buy 2 more of the belkin hubs.... I also took the monitor out and ran a shorter USB line, which helped a tiny bit. The USB cable runs along side the speaker wiring for the speakers, the usb cable for the radio, the cd rom cable and the obd2 (which has a ferrite magnet already) so I am guessing this is causing the screen issues. If it does happen to be the screen, how do I repair it?
Please give me your opinions and input!!!!
Thanx in advance!!!!
