Results 1 to 6 of 6
Thread: Will mac parts work with carPC
    fka - Nextabyte_Matt ioi8's Avatar
    Apr 2006
    Cleveland
    I want to install a slimline dvd drive as my mine drive. I want it to be a lot load, and those are hard to find. I did find a few slot load mac laptop drives on ebay, and I am wondering if those drives will work?
    I know that I need an adapter to convert from 50 pin to the 40 pin ide. But is the mac drive any different then the drive in a laptop pc?
    Nov 2007
    Same question here, but will be connecting via USB instead of IDE.
    Feb 2007
    Nr Aylesbury, UK
    Quote Originally Posted by ioi8 View Post
    I'm using an Intel Mac Mini, the CD/DVD drive in that is the same form factor as a laptop drive, the laptop drives using a smaller high density connector to a printed circuit board, the circuit board connections to the mainboard via a small ribbon cable..
    Have you considered de-casing a portable USB DVD drive, might be easier
    Carl
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    unless your carputer is close to where you'll be mounting the slot-load DVD drive, then you should use USB, not PATA (IDE). the PATA specification limits cable length to 18". some people use longer cables and it works fine, others use longer cables and the drives don't work, or malfunction. USB has limits too, but much longer than PATA. the USB specification limits cable length to 5m (~16').
    I'm not sure about whether or not a 50-pin to 40-pin adapter would work. I don't think it's worth fudging around with it when there are drives that you know will work with your PC. >>>here<<< is an eBay seller that has a few to choose from.
    Nov 2007
    I've got a G4 slot drive and a G4 tray drive sitting at home already, also have a 50 pin ide to standard ide adapter so will give it a test as soon as I track down the a molex to floppy power adapter.
    Nov 2007
    Thumbs up
    Quote Originally Posted by ComputerGeek View Post
    Not to contradict... but... That length is only stable on USB 2.0 devices, Otherwise don't go past 10... or so they say
  1. Could mac slot loading DVD/CDRW work with PC
    By tiomka in forum General Hardware Discussion
    Last Post: 05-16-2006, 07:57 PM
  2. FS: Mac Mini CarPC Package/Parts LOADED!
    By markcc01 in forum Classified Archive
    Last Post: 01-03-2006, 11:47 PM
  3. Miami CarPC parts?
    By RoyN in forum General Hardware Discussion
    Last Post: 10-02-2005, 08:32 PM
  4. newbie parts for carpc
    By cronosxone in forum Newbie
    Last Post: 07-01-2005, 02:37 PM
  5. RR doesn't work in my CarPC
    By dsoares in forum Road Runner
    Last Post: 05-11-2005, 10:35 AM
