Results 1 to 2 of 2
Thread: Reverse Cam Guidance.
    Newbie ax_foley's Avatar
    Oct 2007
    Norwich, UK
    Hi all,
    Quite new to this but enjoying every minute..
    I have an M10000 board but with no type of PCI or USB video TV card etc.. Do I need to have something like this installed for me to get my reverse CAM working with a pluggin i.e. Centrafuse's. I have it working off my AV" on the 7" no probs but as it's not going through the PC's OS I cannot record etc..
    Any pointers wouold be really appreciated.
    Thanks heaps.
    FoleY.
    CarPC in development for.. MkIV VW Golf GT PD GTI TDI 150 (190) - Now that's a mouthful.. but it goes like S***!
    Mar 2006
    Colorado, but Canadian!
    Yes you need a video input device. And just so you know, the M10k sucks big time with CPU intensive tasks. I am sure Centrafuse is tasking it to the max already. This means you cannot use the el cheapo $20 usb/pci card. You need one with a dedicated hardware encoder/decoder chip so it doesnt bog down the CPU, but that gets expensive fast. Usually price is a good indicator of how parasitic it is.
    Also there have been posts around that use a seperate hardware box to overlay GPS speed or text of somesort and record to a tape or harddrive or something without the PC. Not sure you reason for wanting to record, but if it is for fighting tickets, independant with overlay is the way to go.
    If just for a backup cam, it is not worth the hassle with the M10. The performance hit of writing a stream to the HD as well as video processing far outweighs the "cool" factor.
    1.9in x 2.9in -- 47mm x 73mm
  1. Reverse Cam autoswitch?
    By sanjaym in forum Centrafuse
    Last Post: 05-28-2009, 10:18 AM
  2. Which one is the 12v wire on this reverse cam (pic inside)
    By Sonicxtacy02 in forum General MP3Car Discussion
    Last Post: 02-08-2006, 09:26 PM
  3. K301 Reverse cam wire
    By keanpedersen in forum LCD/Display
    Last Post: 08-15-2005, 04:53 PM
  4. reverse cam on xenarc video2
    By kuo in forum General Hardware Discussion
    Last Post: 05-29-2005, 12:33 AM
  5. * WRX STi Infrared Reverse Cam mounted in tail light *
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-07-2004, 01:38 PM
