Hi
I have a fairly straighforward system (see sig). But over about 1 hour my 900 Mhz Celeron will overheat temper to 40 degrees causing a shutdown. I use the standard fan and heat sink that comes with the SV24 mobo.
I know I could use a bigger fan and heat sink but that would mean I loose the PCI slot in the SV 24 case! (I did build a custom case but I would prefere to use the one it came in)
I use an MGPower MPD-810 PSU and I do not know how much strain I can put on this with extra fans etc
I heard ..somewhere that certain celeron CPU's had been produced that could run without a heatsink and fan or at least just a heatsink? Is this true and can you get them for socket 370?
Any help much appreciated
Lilliput 8", C134 EPIA-M 900 (Black), A1-ITX, 256 Mb RAM, 40 Gb HDD, DVD, 802.11g, mini keyboard
